sharktooth question
Old Oct 31, 2013 | 09:04 AM
Rob90spec's Avatar
Rob90spec
Default sharktooth question
i've got a set on my escort mk4 at the mo and they have a 5mm spacer fitted on the rears only,i re-fitted them without the spacers and they don't rub but was wonderering if there was any reason they would have them??
also,i'm picking up a set of 17's to fill the arches,if/when i sell them whats the going rate for 4xmint rims/tyres?
many thanks rob
Old Oct 31, 2013 | 09:17 AM
bagginsRSturbo's Avatar
bagginsRSturbo
They used to space out the wheels to bring them flush with the bodykit, the wheels gotta be worth Ł200+
Old Oct 31, 2013 | 09:47 AM
Rob90spec's Avatar
Rob90spec
smashing,i'll throw the 17's on without the spacer and see how they look 1st ...just praying i don't have to change out the -60mm drop
Old Oct 31, 2013 | 10:07 AM
marky_g's Avatar
marky_g
Fleet Manager
Doubt you'll get away with 60mm and 17s mine uses to screen change to change to 30 and konis on hardest setting
60mm on the front used to eat wheel bearings and gearbox seals
Old Oct 31, 2013 | 10:12 AM
Rob90spec's Avatar
Rob90spec
i've got 15mm between the top of the tyre/wheelarch at the front
and 20mm at the rear with the 15's on.
the koni's are rock hard as is but roll on"tinkering time"
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
