2004 Mondeo 2.0(130) tdci
Old Oct 30, 2013 | 10:24 PM
kusunagi's Avatar
kusunagi
Default 2004 Mondeo 2.0(130) tdci
Hi all,
New to this forum and looking at getting the car in the title. Just looking for advice on what to look out for before I buy. I'm told electrics and suspension,but I always check forums first. it has full service history and has covered 74,000 miles.
Any help much appreciated
Kus
Old Oct 30, 2013 | 10:27 PM
reithy's Avatar
reithy
Main ones injectors, rear sub frame bushes, dual mass flywheel.
Old Oct 30, 2013 | 10:40 PM
kusunagi's Avatar
kusunagi
Thanks for the quick reply.
I did wonder about rear bushes as its been used to tow something as the electric plug is there but no tow arm. I'll check them out best I can. Injectors I'm guessing looking for jumpy acceleration at high revs? Flywheel I'm not sure what to be checking for?
Kus
Old Oct 30, 2013 | 11:01 PM
Nick 172 Sport's Avatar
Nick 172 Sport
clutch looked at loads every tdci i looked at when you put your foot on the clutch it rattled so bought a petrol instead
Old Oct 31, 2013 | 10:57 AM
It's Czech Mate's Avatar
It's Czech Mate
That was the tensioner pully rattling probably
Old Oct 31, 2013 | 11:27 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Originally Posted by kusunagi
Hi all,
Kus
Electrics and suspension are the least of your worries!
It's all about the injectors! Low mileage doesn't always equate to a good buy. It could be argued that one with higher mileage that has gone through the 'danger zone' of injectors failing is a better bet.
If it's had no work done on the fuelling side of things, and has not had a replacement DMF/Clutch, then be prepared that these may need doing in the next 10-20K, and they'll be expensive. You could get lucky and do loads of trouble free miles, just buy wisely, and walk away from any car that has even the remotest hint of running problems.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
