Mk1 focus tdci alternator squeak
Old Oct 30, 2013 | 04:23 PM
marky_g's Avatar
marky_g
Fleet Manager
Default Mk1 focus tdci alternator squeak
Sure mines stated squeeking, but I've just looked online for a replacement seems that's it's got a shaft and bearing tensioner the clamps to the alternator itself
Is the tensioner part of the cam-belt assembly?
An exchange unit at local motor factors it's 113 quid and I don't know if that's both parts or not lol
Old Oct 30, 2013 | 06:12 PM
If its similar to a tranny connect the aux belt tensioner is at the back of the engine and the pas pump bolts to it.
Old Oct 30, 2013 | 07:47 PM
marky_g's Avatar
marky_g
Fleet Manager
Yer I assume it as as a connect is a mk1 focus engine bay and it uses the same 1.8 engine
Is the alt at the rear of the engine then? It sounds like alt belt squeel on a bearing so looking at the parts available I'm guessing it's prob the tensioner
Old Oct 30, 2013 | 10:07 PM
On the connects its at the front but im sure on focuses the alternator drives something else too.
Old Oct 30, 2013 | 11:21 PM
B19 JUB's Avatar
B19 JUB
more than likely the extension shaft of the alternator.has a bearing and rubber bush on it which sometimes collapses or splits.worth taking that off and giving it a spin
Old Oct 31, 2013 | 08:29 AM
marky_g's Avatar
marky_g
Fleet Manager
It's typical I went out there to have a look this morning and no bloody squeel lol
Had a quick look through the Haynes manual too seems the aux belts dose bloody loads on the tdci engines! I may start with the tensioners and a new belt and see how I go Ita defo some sort Bering squeel
jonfoc
16
Sep 11, 2018 05:35 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
jamie956
21
Sep 16, 2015 06:24 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
IanC
Sep 5, 2015 09:38 PM
