Random idea lol
Has anyone tryed turbo in a puma is it possible is there any chance to get manifolds to fit would the engine block cope or how much bhp could it max out at
Could you bore it out to 2.0 ??
Theres one (turbo puma engine) in the project area on XRTWO Forum saw it recently,
http://www.xrtwo.com/forum/viewtopic.php?f=10&t=79403
Depends what you're after, you'll never get huge numbers from the engine itself, but there's no reason not to do it.
OC ran 300bhp on a 1.6 comfortably.
You'd need custom everything as I don't think there's any off the shelf manifolds.
With something like a stage 2 T3 I think you could have a very punchy set up.
http://www.lightningmotorsport.co.uk/tuningkits.html
I was thinking could do it to the fezza ad the engine will be eater to fit that Zt and I was gonna put the engine in a xr3i or orion
What you guys think ??
There was a TZSE on eBay not long back. Can't remember if it had forged internals or not. I suppose running a really low boost application wouldn't cause too many problems but what's the point? I've heard some corsa lads stick diesel turbos on stock engines for minimal improvements at turned down boost. It begs the question why? Unless it's just because they can.
Have a plan, that's the only advice I could give you. I know your doing your conversion on the Fezza so put your 2.0 to one side, strip it to bits, gather parts and when it's ready bang it in.
How's the 2.0 process going btw?
I am looking at doing one in a light weight 3dr sierra
I will make most of the bits , and just keep putting abit more boost in it till I find the limit
I will put some decent internals in it and see how it goes lol
It's got to be worth a go,
Like I said it will have good internals
I will make a plenium and exhaust manifold
Plus it gives me a reason to make a dry sump kit
For it.
It will be on f88rs ecu .
The engines are light to start with so I am on to a winner ( I hope lol) already
For it.
Just a guess, but perhaps it's the aluminium construction? Obviously not built with huge strength in mind compared to some ally engines.
I did think , if I have any issues with the construction strength wise then I will just part fill the water ways with concrete , like they do drag cars but not to that ex stream
I'm not sure on the strength issue. A load of high performance cars use full alloy blocks. And to say these engines are made to rev to high heaven for the power must be made strong structure wise! The only thing that would make me think really if I was going to do it, would be those damn liners.
Oh and the vvt.
Oh and the vvt.
The liners are there for a purpose it's just they wear after time. If you were to spend big money on building it maybe worth looking into a longer lasting material. Having said that if looked after and serviced they are perfectly fine. But who knows about accelerated wear under boost pressures??
http://www.projectpuma.com/viewtopic.php?f=64&t=6583
One in progress
http://www.projectpuma.com/viewtopic...turbo&start=75
chris m1
Sep 7, 2015 08:02 PM
