Lynx tdci fuel pump
Hi lads,
Since there are so much failed pumps around i'd like to ask a question.
Is there anyone who ever dismantled one to see what actually failed?
I'm pretty curious what could be the cause and result of pump failures.
If someone has a failed pump lying about but doesn't want/know how to dismantle it please let me know if you'd like to give it up for science
Cheers!
Cheers!
Would be interesting to know too. Where I work we have a fleet of transit connects and we have only had a few with pump failure. For example out of say 50 vans only 5 have had the pumps changed so not many really.
Seems to be Transit/Mondeo pumps that fail more often than the Focus/Connect ones.
Early ones had problems with the 'rollers & 'shoes' in the hi-pressure pump failing and filling the whole system with swarf.
It's the swarf that kills them - As GVK points out it does seem to be the early ones that were the most likely to die. Running them 'dry' definitely did them no favours, as the diesel acts as a lubricant. But ultimately I'd say the fault lies with the pump being badly designed in the first place!
I have a Lynx engine in my MK4 Mondeo and there is absolutley no way you can prime the fuel system. There's no lift pump and no hand primer. The only half decent way to do it is to fill the filter bowl with diesel and use easy start to get the engine to spin fast enough to pump all the air out the lines.
Absolute crap design and cringe every time I do it!
Normally use a hand primer in line with the filter when servicing them.
http://www.ebay.co.uk/itm/8-MM-FUEL-...-/130983742042
Need some hoses to match up with the fuel pipe connectors.
I bought a draper hand primer but there's no way using the attachments that come with it to connect it together. They use a funny connector where you have to pull a pin out to unplug it rather than the usual push fit connectors.
JK12
33
Apr 26, 2021 12:09 PM
