focus rs gearbox convershion
Old Oct 29, 2013 | 08:23 PM
Layland's Avatar
Layland
Default focus rs gearbox convershion
hi all am going to put a focus rs gearbox in my zetec turbo mk3 fiesta and just had a few questions to ask the first one is does the fiesta zetec s pedal box fit into a mk3 fiesta so the fluid clutch can be used, also will standard 2.0 focus driveshaft's,gear selector +cables fit the focus rs gearbox cheers
Old Oct 29, 2013 | 10:43 PM
Gadget's Avatar
Gadget
Spanner monkey
You want to speak to crazycage on here, he can answer all your questions!
Old Oct 29, 2013 | 10:51 PM
frsjon's Avatar
frsjon
as above lol doubt the shafts will be any good other wise we would all have them,the 2.0 petrol gear lever and cables will work though
Old Oct 30, 2013 | 07:33 AM
robp-tt's Avatar
robp-tt
ZETEC TURBO
A ka peddle box is a better swap.all you need to do is make the hole bigger for the clutch pipe to go through the bulkhead and the throttle cable is in the correct place aswell. You will need to have custom shafts made aswell
Old Oct 30, 2013 | 04:50 PM
Layland's Avatar
Layland
Cheers guys I will have to nip to my local scrappy and see what they have got and c if I can get any rs shafts from eBay lol
Old Oct 30, 2013 | 05:11 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
You won't need frs shafts, 2.0 mk3/2 mondeo or normal 2.0 focus shafts with do as donors for your custom shafts
Old Nov 3, 2013 | 07:24 PM
Layland's Avatar
Layland
Do the mondeo/focus driveshafts fit into the focus gearbox okay then
Old Nov 3, 2013 | 07:41 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
If there 2.0 shafts they will fit into the rs box ok
Old Nov 3, 2013 | 08:43 PM
wildheart's Avatar
wildheart
Do you not need the later 3.5 hubs for this conversion?
If not surely its still a wise move so you don't kill wheel bearings every five minutes.
Old Nov 4, 2013 | 05:26 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
You dont need to use the later 3.5 hubs (ka hubs are the same aswell) but it is best to because of the better wheel bearing designe and I think the cv joints are stronger aswell
Old Nov 12, 2013 | 05:30 PM
Layland's Avatar
Layland
Can I put the 3.5 drive flanges into the mk3 fiesta hubs and will I need to put the 3.5 bearings in as well cheers
Bransby
Sep 11, 2015 09:12 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
gingeRS
Sep 4, 2015 06:29 PM
