Vacuum Hoses SP
Old Oct 29, 2013 | 08:16 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Default Vacuum Hoses SP
where do the vacuum hoses go to and from on a 4x4 escos?
they are all off at the moment and dont have a clue where they have to go to and from, i also want to buy some new hose to do them with anyway.
any ideas?
rob
Old Oct 31, 2013 | 04:10 PM
James @ M Developments.'s Avatar
Pretty easy,
Fuel reg
Map sensor
Dumper
Boost gauge
Purge valve if still fitted from carbon canister.
The fuel reg and map sensor should be on there own lines, and un cut as they are engine critical.
Old Oct 31, 2013 | 05:44 PM
Billy_RS's Avatar
Billy_RS
What about Amal valve?
Old Oct 31, 2013 | 05:52 PM
paul16v's Avatar
paul16v
Monte 087
That gets pressure from the Turbo not the plenum
Old Oct 31, 2013 | 05:54 PM
Billy_RS's Avatar
Billy_RS
I've got mine in bits and the Amal valve has 3 ports. One goes to the actuator. One goes to the turbo compressor housing and the 3rd goes to the ????
Old Oct 31, 2013 | 06:17 PM
fraser9764's Avatar
fraser9764
... nowhere
Old Oct 31, 2013 | 06:22 PM
The Escort cosworth doesn't use an Amal valve,
The valve the escort uses is only 2 port, one going to the air box the other to the jetted tee piece
Old Oct 31, 2013 | 06:25 PM
Billy_RS's Avatar
Billy_RS
Makes sense now. Cheers
Old Oct 31, 2013 | 09:30 PM
Ebonycossie4x4
thanks guys.
ive seen kits that kind of lock on, are they worth having or a load of poo...
other than that just any vaccuum pipe will do i suppose, all the pipes have joiners!
there is one going in to the car aswell seems to be near the ECU? maybe thats going up to the boost guage.
Fudgey
21
Sep 30, 2015 06:19 PM
