More bits for project ' Queen '.
Old Oct 28, 2013 | 05:40 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Default More bits for project ' Queen '.
Must admit ive not seen them yet but Mark posted these pics on another Forum.
I contacted Jenvey to supply a ITB setup to support 1000bhp for project 'Queen'. It comes with duel fuel rails to supply the 8off 1000cc injectors.
It has a more modern contactless P&G TPS to replace the Weber PF01.
This is for an engine being built just for fun. Will have to cope with over 50psi of Boost & probably E85 fuel. With old age comes madness .
Old Oct 28, 2013 | 05:43 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Horny bit of kit!!
So is this what your state pension is paying for :P
Old Oct 28, 2013 | 05:44 PM
stuart collins's Avatar
stuart collins
nice I have a set for mine
Old Oct 28, 2013 | 05:46 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
50psi
Stunning bit of kit though!
Old Oct 28, 2013 | 06:24 PM
Jasu's Avatar
Jasu
Looks nice Rod.
Old Oct 28, 2013 | 07:19 PM
Paul_RS's Avatar
Paul_RS
Get it built and get some records broken
Old Oct 28, 2013 | 08:10 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
This is not for record purposes ive a Spec. already decided for that this is for fun only.
Old Oct 31, 2013 | 01:57 PM
AustenW's Avatar
AustenW
Very Nice
Old Oct 31, 2013 | 02:28 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Heard from Mark last night my new Spec head will arrive tomorrow.
Slightly tweaked ports, new type valve springs & different but Standard size valves. I must make time to get to see these new parts before Mark flys to Vegas on Monday .
Old Nov 1, 2013 | 12:08 PM
opposite lock's Avatar
opposite lock
Looks great Rod , 50 psi
Old Nov 1, 2013 | 12:15 PM
turbomook's Avatar
turbomook
Porn!!
Old Nov 1, 2013 | 01:50 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Went over to Marks today first time for a month or so. Quick pics of the bits that have arrived. Jenvey, Borg 9180 & the tweaked head with new valves. Mark also had a chat with his cam people about a mild tweak to the exhaust cam. Small change to lift & duration but nothing drastic to spoil the mix we had on the last engine its been ordered. Will push this set up a lot further with extra boost up to 3.6bar.
Old Nov 1, 2013 | 02:08 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
3.6 bar. will be immesne.
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
3.6 bar of boost lol your have to be strapped in or your get sucked out the window when that comes on boost!
Old Nov 1, 2013 | 02:27 PM
BLU's Avatar
BLU
BLU is the new black :)
Wow thats gonna be an animal - 50psi
You'll have to make sure you've got a filter good enough to stop small animals, people and whatever else that is around - that isn't strapped down - from being sucked into the engine
Old Nov 1, 2013 | 05:13 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Nothing happens for months & then it all happens at once .
The part we are having made to help with Block integrity is complete & ive just payed for it . Cost a tad more than discussed but its a first for a YB & was a tad more difficult to develop. Will be taking all the bits to the Vibration people to get balanced as a unit after Mark gets back from Sema. Think Mark has other idea as well that will be discussed at the time. We are giving this a good shot lads it wont be easy.
Ive always stopped Mark going for big Power cos I needed to drive this thing to the Darby & Jones club but having two Spec's will i hope give the Tall one a crack at some big numbers. If it fails thats life but if we dont try I think I will always regret it in later years as I consider mods to my my zimmer to make it handle better .
Old Nov 1, 2013 | 06:53 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
50psi will certainly keep you on your toes,
Jenvey make some awesome bits of kit
Are you going to have the spec/power switchable or is it going to run around the 1000bhp mark all the time
Old Nov 1, 2013 | 09:57 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
The 1000bhp is for the Dyno with a gtx4202 running 50+psi.
In the car it will have a bw efr9180 running 40+psi in the mid 800's.
What we will use on a Topspeed run is not yet decided.
Old Nov 2, 2013 | 07:44 AM
gingerturbo
Even the mid 8's is going to be a fun toy,
Top speed will be good to see are you still using the same ratio box as the last run
Old Nov 2, 2013 | 08:00 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Using the 19" wheels 8.3K in 5th is 219.3mph we simply wont have the Power to pull that so yes we have the gearing covered. Aim is 214mph which should be possible with 820 +100 shot of Nitrous. Remember these figures are easy to quote but not so easy to achieve so mean nothing at this time.
Old Nov 2, 2013 | 09:28 AM
costina's Avatar
costina
Live long and prosper!!
Just out of interest Rod what does your car weigh?
Old Nov 2, 2013 | 09:33 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
No idea but way more than standard it has lots more sound proofing, heavier gearbox & axle, Nitrous kit & dry sump.
Old Nov 2, 2013 | 12:18 PM
Paul_RS's Avatar
Paul_RS
Breaking records is fun surely?
Old Nov 2, 2013 | 01:31 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Are technical achievements fun not at the time thats for sure.
Putting a 25k engine on the line is not fun either & few do it.
27 runs todate 2 ended in failure & they deffo were not fun .
Old Nov 2, 2013 | 01:32 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I bet it's a little nerve racking putting such a high spec engine under full use for the first time!
Old Nov 2, 2013 | 03:47 PM
gingerturbo
Anything over the 200mark is respectable, I'm sure you will achieve 214mph, are you testing it at bruntingthorpe
Old Nov 3, 2013 | 09:05 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
We achieved 210mph back in 2005 unofficially with circa 840bhp it will take about another 80/100bhp to hit 214 so its not easy but we will give it a bash. Will final map & set up Nitrous at Brunters & if conditions are good theres no point going twice.
Old Nov 3, 2013 | 09:39 AM
nixon_2wd's Avatar
nixon_2wd
Crazy project, Rod
Old Nov 3, 2013 | 10:32 AM
gingerturbo
Yeh true that, me and a friend came back in a recovery truck yrs ago at brunters trying to push an escort to its limit, and we was getting stressed over 2mph as we hit 148mph and couldn't get no more out of it and we taped up everything for aero and eventually it went pop, so yeh getting a few extra mph is a massive challenge
Old Nov 3, 2013 | 11:37 AM
lee2cossies's Avatar
lee2cossies
Good stuff rod, great that your continuing developing it. If u run the 1000hp engine with nitrous on top would it hold together? And if so how fast do u think it would go at bringers then?
Old Nov 3, 2013 | 12:59 PM
opposite lock
How else aerodynamically can your car be improved , At these massive speeds i,m thinking about underside , even the diff and such like would cause quite a drag loss. ??
Or is there an undertray or similiar to help or is it not really an apparent problem?
Old Nov 3, 2013 | 01:02 PM
Sonic Boom's Avatar
Sonic Boom
How does the idle control and or anti lag by pass work with these inlets?
Cheers Rich
Old Nov 3, 2013 | 01:07 PM
Sonic Boom's Avatar
Sonic Boom
I thought the inherent problem with smooth undertrays is without sufficient downforce at high speeds they have tendency to cause lift, see Mark Webber in the 1999 Le Man.
But i'm no aerodynamicist
Rich
Old Nov 3, 2013 | 01:16 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Cheers Rich
Jenvey supply a distribution block for idle or any other manifold input.
We are using two distribution blocks in this application + a 3rd drilling in each throat for Nitrous.
Old Nov 3, 2013 | 01:18 PM
Mark Shead's Avatar
Mark Shead
Cheers Rich
There will be 2 pipes on each runner joining in to 2 inlet blocks so one for idle control and one for DV map fuel.
Mark
Old Nov 3, 2013 | 01:28 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Its not a route we have taken but we use a 4x4 undertray. At these speeds we have seen a bonnet bend at the edges so we now have aero pins. Indicator clusters will simply blow away wiring & all if you rely on the springs supplied these are now held with self tappers. Was at Brunters when a sun roof blew out fixings and all at 170mph so we tape that down. We run 17" front & 19" rear to run front down with a RS500 style front lip thats about it.
We have considered a flat floor & a parachute but these need testing to get right.
When the next generation trys to beat these times & they will im sure all these other area will be explored but where do you stop. We go as fast as possible with lots of grunt nothing else really.
Old Nov 3, 2013 | 01:38 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
What 30+secs at WOT i very much doubt it would hold together for anything like that time. With the 'push' system activated that would be 1250bhp . Anyway we have not seen 1000bhp yet that may only be 900 we dont know untill its tried.
As for a theoritical speed we need to lengthen the gearing thats for sure so more Power to pull it so I guess a very romantic 235mph if the fairies visited earth for a day. Striving to get 940bhp to run the length of Brunters is more than a challenge im sure .
Old Nov 3, 2013 | 01:47 PM
lee2cossies
If it did hold together that would be incredible! See what u mean tho not worth risking.
I don't think anyone will attempt to challenge u sadly, plus it would take a very special car/engine combo which is very unlikely to happen.
Old Nov 3, 2013 | 02:14 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Using a Ford YB Block/Head you may be correct. Some see these new alloy Block/Head as being a YB but im sure Ford had no input they are a copy with the warts sorted. If i were to go away from the YB then it would be a v8 or a v10 to get real Power.
Old Nov 3, 2013 | 02:22 PM
Miller 3's Avatar
Miller 3
But surely as soon as you start modding things like inlet, turbo, pistons, crank, rods, ect thats just the same as having a different block/ head combo and not as ford intended?
