Which spray glue for headlining?
Ive tried 2 types and the head lining has just sagged again.Make sure you get all the old orange glue off first.The best way would be to take the cloth off and glue a new cloth on.
The stuff I used was in a red and white tin with black writing on it.I cant remember what it was called.
I used some from a company on ebay called as trim, was as above a red and white tin with black writing called fast fix high temp spray glue and has held for 3 years so far
I've just done a p38 headlining in alcantara
Only tips I can give are make sure all the old glue is removed or nothing will stick no matter what glue you use.
The best glue is a contact adhesive, a thin smear over both surfaces and leave for 15 - 20 minutes before putting together.
rsguy
44
Sep 29, 2015 03:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Vacuman
Sep 22, 2015 12:09 PM
