Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
1.8 TDCi Poor fuel consumption
Old Oct 27, 2013 | 05:52 PM
Jonny Mercer's Avatar
Jonny Mercer
Default 1.8 TDCi Poor fuel consumption
I recently bought a 1.8 TDCi 07 with 71,000 miles on the clock and I'm pretty sure something isn't quite right with it. I reset all the computer when I got it and I seem to be getting only 33.2 mpg average and around 400 miles from a full tank from mixed driving. There are no lights on the dashboard but I plugged a code reader in and found 2 codes in the ECU; P0299 - Powertrain & U0423 - Network. I don't know if these are contributing to the problem or just old codes that have never been removed.
Any ideas guys?
Old Nov 10, 2013 | 06:02 AM
Adeebbouk's Avatar
Adeebbouk
Any ideas guys?
Hi Jonny I have the same issues as you I believe geting around 35mpg and very sluggish low down in the revs although seam fine at everything else my car is a 2009 1.8tdci with 70000 I jst thought that's how the were until I drove my mother in laws 55plate 1.8tdci what has 110000+ on the clock and it had bags of power and does 50-55mpg
Really need to fine out the issue as there is clearly something funny goin on I will keep you posted if I find anything please do the same thank adrian
Old Nov 10, 2013 | 04:09 PM
Jonny Mercer
I think the problem I had is different to yours. My problem was that some muppet serviced my car before I got it and forgot to plug in the sensor on the fuel filter. Fuel economy has shot up and just had a weekend away to Brighton and there and back got an average of 53 mpg.
Does your car make strange noises or smoke a lot when setting off?
Old Nov 10, 2013 | 04:27 PM
oldford's Avatar
oldford
The P0299 code could be the problem. It means you don't have enough turbo boost.
Could be a leak in a turbo hose, but it could also be a turbo problem or something wrong with the way the boost pressure is controlled.
Old Nov 10, 2013 | 06:46 PM
Adeebbouk's Avatar
Adeebbouk
Nope no smoke or noises that's the thing that I carnt seem to understand other than the lack of power and fuel consumption the car seems fine all pipes seem to be fine very strange
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
liamT74
Sep 23, 2015 10:24 PM
pie-face
Sep 15, 2015 10:43 AM
talon1
Sep 15, 2015 10:27 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
