need help on fiesta rs camshaft?
Old Oct 24, 2013 | 02:53 PM
hulsey09's Avatar
hulsey09
Default need help on fiesta rs camshaft?
hi i have took the cam out of my fiesta rs turbo and at the end it says k 97! is this a standard camshaft? am just not sure
Old Oct 24, 2013 | 04:49 PM
rsmark86's Avatar
rsmark86
Is it machined in or sort of painted on?
Uprated cams have them machined in
But that number does not match up too any of the uprated cams on sale
Kent would have cvh??
Piper would have 285?? Ect and so on
Seems standard too me
Old Oct 24, 2013 | 04:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Could be a pattern part.
Old Oct 24, 2013 | 04:57 PM
hulsey09's Avatar
hulsey09
hi yes its is machined but it had piper pulley on and it moved and bent the vaules!
think it is standard but not 100% tho
Old Oct 25, 2013 | 07:21 AM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
It'll be a pattern part. I had piper verniers on my old saff and the fuckers slipped twice. Wrote off my engine
Old Oct 25, 2013 | 08:37 AM
Karlos G's Avatar
Karlos G
Balls Deep!
I didn't think there was enough adjustment on most verniers to allow piston and valve contact? IIRC A CVH cam belt can be three teeth out and still not contact.
Old Nov 7, 2013 | 08:22 PM
hulsey09's Avatar
hulsey09
yeah it was a standard cam, and it did slip there was only minor marks on the pistons,and bent one valve. i didnt put the piper vernier back on just went back to a standard one to save the hassel of it doing it again!
Old Nov 9, 2013 | 06:03 PM
Brendan's Avatar
Brendan
struggling with reality
If you want to go for an adjustable cam pulley get it it hard anodized. I know this means it is grey colour but it stops the aluminium wearing and it slipping! Newman will get you one to order! They did for me! otherwise a steel one is the solution.
Also spend some time checking the cam itself as the build quality is very variable! I had some problems with the Kent cam I ordered to start with!
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
