best place for new panels ??
as above ,wheres the best place to go for replacement panels for my mk3 escort need 2 wings .seen some cheap crap in the past that's started to rust through the paint after 7 months
Hi, i don't know if this helps... found it the other day, they seem to have quite a few bits, but some of the prices are a tad high
http://www.motomobil.com/produkte,32...tegory_id=9&q=
if they rust through quickly it is usually down to bad preperation the black primer that comes on most panels is only to stop surface rust while they are on sale and it should all be removed to bare metal prior to painting properly, thinners with a cloth will usually take it off. if thinners doesnt move it then they are e coated so leave that on but only the expensive panels are e coated
Got my lads rst panels from there and the quality is great
chowfornow
14
Jan 5, 2019 09:01 PM
