saphh 4x4 front end knock
Old Oct 22, 2013 | 06:28 AM
timster's Avatar
timster
Default saphh 4x4 front end knock
Hi peeps got a noise coming from the front of my car which doesn't show itsrlf all the time. It's a clunking noise that sometimes can be felt through the pedals/floor of the car. Have changed front shocks, tca bushes and anti-roll bar ones. The front prop is fine with no play, any suggestions? There's no play in either the wheel bearings or ball joints either
Old Oct 22, 2013 | 06:33 AM
Are your bottom ball joint pinch bolts tight. I had a knocking noise on my saff when I was driving down the road and turned the steering wheel side to side it used to knock like fffooook.You could feel the nosie through the brake pedals and steering wheel and floor.
Cosworth Lad's Avatar
Cosworth Lad
Had this with mine years ago turned out my exhaust was loose from down pipe and was just touching the chassis hope this helps mate
Old Oct 22, 2013 | 07:11 AM
timster's Avatar
timster
Would think they are tight Glen as they've been out and back in when changing the tca bushes and was present before hand. Will have a look at the downpipe also had a vibration through the car when last out in it although it's since disappeared free wheeling or in gear
Old Oct 22, 2013 | 08:28 AM
cossiestu's Avatar
cossiestu
Does it do it while turning from lock to lock? I had that once, one of the steering rack bolts were a bit loose.
Old Oct 22, 2013 | 08:57 AM
timster's Avatar
timster
Haven't tried that, just makes a clunking sound sometimes when on the road or going over speed bumps but can be through the pedals/floor or just a sound without anything else
Old Oct 22, 2013 | 09:04 AM
kosman's Avatar
kosman
sideways all the way!
the exhaust used to catch the bellhousing on my saff and did the noise your describing,mine was 2wd though
Old Oct 22, 2013 | 09:16 AM
anglia105e hinson's Avatar
anglia105e hinson
Mate I had this same problem it turned out it was the front diff bearings where shot!
The drivers side one !
I bet it's this mate,
Take the shaft out the tri lobe joint and grab hold of the cup mine had side to side movement .
I but my spare diff in and bobs ya uncle no noise!
Luke
Old Oct 22, 2013 | 10:49 AM
timster's Avatar
timster
Tbh I've thought it could be the front diff as it's worse when the car is warmed up
Old Oct 22, 2013 | 10:57 AM
Dezzer's Avatar
Dezzer
4x4 resto
Id check the exhaust downpipe first as it easiest to do , just make sure its not catching front prop or chassis leg when warm , then poss drive shaft knock , will get worse going round corners
Old Oct 22, 2013 | 11:10 AM
Normaly the ujs look brown cause the grease gets dried out.
Old Oct 22, 2013 | 06:28 PM
The Youth.'s Avatar
The Youth.
as said check position of the exhaust where it goes between the chassis and bell housing , it needs to be in the middle
steve
Old Nov 24, 2013 | 06:16 AM
timster's Avatar
timster
Turned out to be the front o/s driveshaft,bearings inside the cup were shot! thanks for the sugggestions folks!
Old Nov 24, 2013 | 07:55 AM
anglia105e hinson
Do you mean the tri lobe bearing yeah?
Glad ya found it mate
Old Mar 9, 2015 | 03:37 PM
timster's Avatar
timster
Well the noise is back folks and when warm now it jerks off throttle. Possibly the Diff?
Old Mar 10, 2015 | 09:45 PM
The Youth.'s Avatar
The Youth.
^^^^^^ what he said
steve
Old Oct 27, 2017 | 06:37 AM
timster's Avatar
timster
Well four years after the original post I finally found out it was the balljoint on the tca. No play or any noises when jacked up in the air, but once pulled apart you could tell it was shot. Shows how much I drive the car lol
Old Oct 28, 2017 | 06:31 AM
gcfcos's Avatar
gcfcos
Lol sounds like my Cossie, makes some weird noises and spend hours upon hours searching for it to no avail and then yonks later doing something totally unrelated I’ll find it
Old Oct 28, 2017 | 02:13 PM
Theres that much pressure on the front bottom arms cause of the roll bar. Its hard to tell if you have play in the ball joints.
Old Oct 28, 2017 | 05:32 PM
Jay,'s Avatar
Jay,
Sponsor
always put them on a shaker plate and generally you find the bottom ball joint hole in the hub has gone oval seen loads lol
Wilsfoci
15
Mar 30, 2016 10:26 PM
C2 MAK
Aug 20, 2015 09:46 PM
Bezzy41
Aug 3, 2015 10:31 AM
