Fitting a heated windscreen, HELP :)
Old Oct 21, 2013 | 05:08 PM
jiminal's Avatar
jiminal
deisel deviant
10 Year Member
Default Fitting a heated windscreen, HELP :)
hi there, ive just finished converting my sierra from boring old 1.8td power to 2.5 bmw power, but ive had to remove the heater matrix to make room for the extra 2 cylinders, ive found heated windscreens online for these but im not sure how you go about wiring them in, also can you change the windscreens in these on your own or do you need a glass specialist?
cheers
Jamie
Old Oct 21, 2013 | 05:19 PM
dangerousbrian's Avatar
dangerousbrian
to wire in you will need the relay and the switch on the dash. as for fitting, unless you get all the correct primers and glue get a glass fitter to do it. by the time you buy the stuff you might aswell pay someone to do it anyway.
Old Oct 21, 2013 | 05:28 PM
jiminal's Avatar
jiminal
deisel deviant
10 Year Member
could i use any relay and switch or do i need a special one for a windscreen? like one for a rear heated screen or something? il get someone to fit it
Old Oct 21, 2013 | 05:32 PM
Acidburn's Avatar
Acidburn
use same sort of setup for rear screen.
if you are unsure about fitting then get someone else to fit it because if it goes wrong it will cost you more in the long run.
Old Oct 21, 2013 | 05:35 PM
jiminal's Avatar
jiminal
deisel deviant
10 Year Member
ok kewl, so i need someone to fit it and someone who knows a bit more about wiring than me, cheers guys
Oct 9, 2015 07:38 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
jay030787
Aug 5, 2015 09:28 PM
