orion project, any advice appreciated
Old Oct 18, 2013 | 11:32 PM
appo94's Avatar
appo94
Default orion project, any advice appreciated
i have recently bought a mk2 onion and being as i have some spare money to throw about and no mrs to tell me where i can throw it anymore i thought i would try and make it as unique as possible...it may sound stupid but i want a 4wd, 300bhp+ orion...the 300 bhp bit im not so worried about but the 4wd im not too sure about....would it be worth the hassle of tryin to get a 4wd system into it or would i be better off with just rwd?? (either way it cant stay as FWD!!) and if so what drive system would you reccomend with what engine?, i have spoke to a few people about it and they have all said the best engine to use for somethin like this would be either the 2l dohc out of the sierra or a 2l zetec from mondeo but i'd really quite like to have a pinto in it, as far as engines go what would you recommend? they have all (bar 1) also said the 4wd cant be done?...as you can tell im probably the furthest thing from an expert in this field so any advice or reccomendations would be appreciated.
cheers
Old Oct 19, 2013 | 09:21 AM
blueovalman's Avatar
blueovalman
If you want to use a pinto engine, have you considered xr4x4 Sierra running gear, failing that use a 2.0 pinto Sierra donor
Old Oct 19, 2013 | 01:08 PM
costina's Avatar
costina
Live long and prosper!!
Why not try rwd as it would be easier and engine and box from a scorpio 2.3 16v would be cool. then slap a turbo on it running lowish boost and management to suit
Old Oct 20, 2013 | 04:39 PM
appo94's Avatar
appo94
no mate i didnt even think of the xr4x4 running gear to be honest i have been looking into the 4x4 escort system as there isnt so much difference between the wheelbase's, but i spose you can interchange drive shafts between the 2 right?
Old Oct 20, 2013 | 04:49 PM
appo94's Avatar
appo94
yh i think this is the way im gunna go for now, im still in 2 minds wether i want to use a pinto or something a bit more modern, st170 or maybe the 220 if i can find 1, would a sierra/escort cossie box fit to an st lump?
Old Oct 20, 2013 | 06:23 PM
costina's Avatar
costina
Pinto will be expensive and parts are thin on the ground. other option is a zetec with a modded mt75 gearbox.
T5 2wd cossie box will fit zetec, 14 2.3 16v Granada lump and prob a st 170 lump
Old Oct 20, 2013 | 07:10 PM
blueovalman
Just a point to note, escort/ mondeo 4x4 is a front bias system were as Sierra/ granada 4x4 is rear bias
Old Oct 20, 2013 | 09:22 PM
studabear's Avatar
studabear
Bank loan or raid savings, which ever is best then get a cossie 4x4 conversion from somewhere like andrew gallacher motorsport or A1 Rally.
Old Oct 21, 2013 | 01:35 PM
appo94's Avatar
appo94
cheers fella, that was my next question
Old Nov 21, 2013 | 12:07 AM
appo94's Avatar
appo94
ok, i'm at the point of cutting and welding and want to keep it minimal so could i use an already made transmission tunnel out of another ford (sierra, mk2 escort, cortina)? i have received some advice from an old boy down the road that used to do this sort of thing alot and he said he used to use the rear floor panels from the sierra and the rest from a cortina, again any advice would be much appreciated.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Marino
Sep 12, 2015 11:10 AM
bassboy
Sep 10, 2015 08:54 PM
RSBryden
Sep 6, 2015 08:39 PM
ST-170
Sep 4, 2015 11:02 AM
