Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Egr blanking plates
Old Oct 17, 2013 | 05:01 AM
paulmtdci's Avatar
paulmtdci
Default Egr blanking plates
My 02 1800 TDCI Estate has a vacuum operated EGR Valve,i want to blank it off,does the blanking plate fit between the valve and manifold? In other words does the valve remain in place?
Thanks Paul
Old Oct 24, 2013 | 12:44 PM
paulmtdci's Avatar
paulmtdci
Default Misunderstood?
Perhaps i've worded my question wrong,does the blanking plate fit between the manifold and egr valve or do you fit the plate and leave the valve out/disconnect it?
Regards
Paul
Old Oct 26, 2013 | 03:51 PM
undie's Avatar
undie
Thumbs up egr blank off
hi I have an 02 1800 tddi and blanked of my egr valve ..got my blanking plate off ebay at a good price ...and yes you do have to leave the valve in place ..all I did was slacken off the 2 10mm nuts and slide the blanking plate in ...which I must add the holes in the plate are slotted for easy fitting
Old Oct 26, 2013 | 04:00 PM
undie's Avatar
undie
Thumbs up
=undie;6357889]hi I have an 02 1800 tddi and blanked of my egr valve ..got my blanking plate off ebay at a good price ...and yes you do have to leave the valve in place ..all I did was slacken off the 2 10mm nuts and slide the blanking plate in ...which I must add the holes in the plate are slotted for easy fitting[/quote]
Old Oct 26, 2013 | 04:05 PM
paulmtdci's Avatar
paulmtdci
Thanx for the reply
Paul
Old Oct 26, 2013 | 05:01 PM
RSBryden's Avatar
RSBryden
10 Year Member
Yeh same as above I fitted mine 4 weeks ago and no smoke and seems more responsive,
Fidly to fit tho, dropped mine and it wedged in behind starter motor , right cunt I had to remove all under tray n starter motor to release it, a 20 min job was 2 hours lol
Old Dec 21, 2013 | 08:55 PM
Mk4 Rick's Avatar
Mk4 Rick
What do you gain from fitting a egr blanking plate on a tddi 1.8 engine
Old Dec 21, 2013 | 09:24 PM
RSBryden's Avatar
RSBryden
10 Year Member
I gained crisper low end acceleration , no smoke n a bit more mpg it seems but don't quote me on that ,
Could be better diesel .
Old Dec 22, 2013 | 10:42 AM
Twizz's Avatar
Twizz
Out of many, we are one.
I read up that if you want to remove the valve completely, the downpipe and cat have to come off to allow you to remove it.
I couldnt be asked with all that hag so just bought the stainless steel blanking plate from eBay, dropped the two 10mm bolts (I left a few turns on it), pushed the pipe down and slid it in. Took less than 10 minutes.
Peformance etc, the EGR operates iirc at low RPM. My focus feels more responsive and smoother with the blank in place, I've also added the ST170 airbox, snorkel and KandN filter which some say increase airflow significantly.
Old Dec 22, 2013 | 10:46 AM
Twizz's Avatar
Twizz
When buying the plates, you'll notice there's ones with open cuts, some with one bolt hole and one cut and some with two bolt holes.
I bought the one with two open cuts so I didn't have to remove any bolts (could just slide in).
Old Dec 25, 2013 | 10:24 PM
Mk4 Rick's Avatar
Mk4 Rick
Are they expensive to buy?
Old Dec 26, 2013 | 08:39 AM
RSBryden's Avatar
RSBryden
10 Year Member
I paid 3.99 off eBay mate!
Old Dec 26, 2013 | 01:02 PM
Mk4 Rick's Avatar
Mk4 Rick
Lol is that it lol
Old Dec 28, 2013 | 02:37 PM
Mk4 Rick's Avatar
Mk4 Rick
Is this the late I need for the X reg TDDI
http://www.ebay.co.uk/itm/EGR-VALVE-...item1e6e2c9119
Old Dec 28, 2013 | 03:15 PM
RSBryden's Avatar
RSBryden
10 Year Member
Looks like the one I bought for my 05 mate
Old Dec 28, 2013 | 03:23 PM
undie's Avatar
undie
not sure about that ..should,nt think there is a lot of difference in them
Old Dec 28, 2013 | 03:29 PM
undie's Avatar
undie
.that's the one I got for my 52 reg
Old Dec 28, 2013 | 03:59 PM
Mk4 Rick's Avatar
Mk4 Rick
Ive ordered one got to be worth a punt for a few quid.I know what people mean when it lacks in the lower gears we are used to driving a petrol car and when the missus first started driving it she thought there was some thing wrong with it.I said luv its called lag lol
bobsworth
77
Mar 24, 2016 09:30 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
