Con rod bolts
Old Oct 15, 2013 | 07:40 PM
Ridgey's Avatar
Ridgey
Default Con rod bolts
When do you need to replace these?
I have taken my crank out for a little work on it, do I need to bolt rods back to it with New bolts?
I don't see why I should need to, but thought I best check.
Old Oct 15, 2013 | 07:43 PM
nevsrevs's Avatar
nevsrevs
I believe you can use arp, s three times as long as they stay within there accepted tolerances.
Old Oct 15, 2013 | 07:48 PM
LHD220Turbo's Avatar
LHD220Turbo
while its apart you'd be a fool not to IMO, replace with ARP's
Old Oct 16, 2013 | 08:28 PM
Ridgey's Avatar
Ridgey
Think I'll replace them for piece of mind
Old Oct 16, 2013 | 08:29 PM
Ridgey's Avatar
Ridgey
Bleeding me dry this bloody car
Old Oct 16, 2013 | 08:49 PM
frsjon's Avatar
frsjon
just to add you should change them as there stretch bolts. just the same as you would change head bolts every time you took the head off
Old Oct 17, 2013 | 08:44 PM
Ridgey's Avatar
Ridgey
I guess that was the kind of info I was after
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
stevecfrst1
Sep 30, 2015 05:18 AM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
