Water injection/rpm pulse help
Old Oct 5, 2013 | 09:37 PM
marky_g's Avatar
marky_g
Fleet Manager
Default Water injection/rpm pulse help
Anyone with a non dizzied (coil pack equipped)car fitter water injection? Removed the earl water injection from my rest and fitting it to my efi turboed xr
Instruction say you need a RPM pulse says I can use the alternator or the crank position sensor but I have no idea which wire to cut into
Old Oct 6, 2013 | 06:46 PM
Brendan's Avatar
Brendan
struggling with reality
don't use the CPS for revs, this is a weak input sinal, and will cause problems use the RPM signal of the EDIS module! if you PM me your email address I will send you pin out wiring diagrams!
Old Oct 8, 2013 | 08:13 AM
Brendan's Avatar
Brendan
were the pics ok?
Old Oct 8, 2013 | 12:11 PM
marky_g's Avatar
marky_g
Fleet Manager
Pics were good mate very clear but what wire is the rpm pile the PIP wire?
Old Oct 8, 2013 | 01:33 PM
Brendan's Avatar
Brendan
no use CTO (clean tach out) on pin 11!
Old Oct 8, 2013 | 08:18 PM
marky_g's Avatar
marky_g
Fleet Manager
Cheers Brendan massive help mate! Have you converted your car to mega squirt?
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
