Pioneer Home Amp
SX 339 Model
Specifications
Tuning range: FM, MW
Power output: 55 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 70kHz
Total harmonic distortion: 0.07%
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 72dB (MM), 97dB (line)
Output: 150mV (line)
Speaker load impedance: 2Ω (minimum)
Dimensions: 420 x 125 x 336mm
Weight: 7kg
Accessories: remote control ( which comes with it and works perfectly )
Ive jotted down when inputs it has on the back and are as followed:
Inputs:
Phono
CD
VCR/Line
Tape1/DAT:
REC
Play
Tape2/Adaptor:
REC
Play
A,B - 4ohms-16ohms per speaker
A+B - 8ohms-16ohms per speaker
This unit is very loud but also has very good sound quality, If collected it can be heard but i will also post it out of need, collection would be from Torquay, Devon
Any questions let me know on 07702 570 905
£50 posted
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
