When foot on brake all lights dim/flicker?
When I'm idling and I put my foot on my brake my dash, head and rear brake lights dim/flicker dimmer.
It's strange, when I press the brake just enough for rear lights to come on the headlights dash and brake lights flicker/dim really quickly for about 2-3 seconds like it's surging/draining power from somewhere.
And if I press the brake, let it flicker, then let go and quickly press brake peddle again it doesn't do it, it's like it has to build up some sort of charge?
My rev counter needle also jumps up quickly then back to its position often, even with just key in to position II a and not started.
Any ideas please?
Thanks
Any ideas please?
Thanks
The lights problem sounds like poor earth connection/corroded rear light connections. Remove the rear lights and check the connections and bulb holders, and the wiring going to the holders. Also make sure correct bulbs are fitted, if a single contact bulb is in place of a double contact it can cause issues.
Have not come across the rev counter fault, possibly be a new instrument cluster required..
The problem is normally down to the connector blocks that plug onto the bulb holders give the prongs on the bulb holders a good clean with some emery paper and check the contacts on the plugs are also clean this normally sorts the problem out.
Thanks, Do you know where abouts in the footwell?
Been reading a lot about this on American forums and found few things to check:
- I'll check the battery terminals for corrosion under the grease.
- seen something called 'The Big 3' which is replacing all the cables from alternator to battery with new larger gauge wire.
- check the pig tail on the alternator for corrosion.
- the wires in the harness from car to tailgate, I did check these but dot know how I would get to them to check all the way along?
I'll start with the pigtail and Battery terminals on Thursday in my day off.
clocks are wired into the rear lights and by the sound of it theres a crossed wire or two expossed wires touching each over. due the reasons of stealing cars i cant say which wires over ride the ingtion but its very unlike to be on the tail lights end. pull the front an rears seats out and follow the loom from the boot all the way around to the fuse box you will find broken or pinched wires along there.
Thats the cause of your problems.
to help follow the light looms from the bumper not the tail lights there the cause.
Random question, is the stereo aerial connected to the lights at all?
I'm loosing radio signal where I've always had it before and I can't pick up any radio station at all and then randomly it'll come back.
So I checked all cables on battery and alternator and they 'look' ok but few of the copper earth cables from battery to inner wing look a bit green at the fixing point in the wing.
I was having a play this morning and at idle if I turn side or headlight on, fog lights on, rear heated window all on their own the lights would dim/flickers as well.
Could that be something to do with the alternator or earthing from the battery?
Dr. Ickxs
Sep 15, 2015 10:15 PM
