Injector washers (TDCI)
Old Oct 2, 2013 | 06:57 PM
leep27's Avatar
leep27
Default Injector washers (TDCI)
Hi. Just wanting to know, the washers at the base of the injectors, are they copper? Do they have to be replaced with copper ones? As there is a seller on eBay selling steel ones. Will there be an issue with this. Cheers.
Old Oct 2, 2013 | 07:13 PM
Harryh24's Avatar
Harryh24
copper usually they are the best ones to use as copper is soft, so helps seal.
Old Oct 2, 2013 | 07:15 PM
botters's Avatar
botters
competant bodger
make sure you recut the injector seats in the head and recut the seat on the end of the injector or it will be pointless changing the washers anyway as they will blow again very quickly
and yes use copper not steel most diesel specialists stock the washers and are generally cheaper than ebay
Old Oct 2, 2013 | 07:18 PM
botters's Avatar
botters
competant bodger
http://www.ebay.co.uk/itm/Diesel-Inj...item20d7d0e51a
this is the cutter i have
Old Oct 2, 2013 | 07:22 PM
Harryh24's Avatar
Harryh24
yeah didn't mention they need recutting, just Hoover out any crap that falls in after cutting, and if they have leaked and all covered in the gunk it's a nightmare, best stuff to use is acetone as it melts it.
the Merc ones are only 0.32€ each
Old Oct 2, 2013 | 07:24 PM
JamesH's Avatar
JamesH
Yes need to be copper, and must be the same thickness.
You can anneal them rather than replacing. But for the sake of cost, replace if available
Old Oct 2, 2013 | 07:27 PM
leep27's Avatar
leep27
Cheers all. Good advice as always. Haynes manual doesn't mention reseating does it? Thanks anywhoo
Old Oct 2, 2013 | 07:41 PM
JamesH's Avatar
JamesH
I've never had to reseat anything, but it's never been after a long period. Would at least get any small bits of soot etc off the seat though
Old Oct 2, 2013 | 07:45 PM
Harryh24's Avatar
Harryh24
depends why they need changing, if it's just because you've took them out then no problem, but if they've been leaking or blowing it will defiantly need reseating as usually makes grooves I'm the head and or injectors.
Old Oct 2, 2013 | 07:51 PM
leep27's Avatar
leep27
I'm changing the injectors as they are goosed. One at a time as I can't afford to do the lot at once. Did a leak off test and injectors 3&4 were just filling my 200ml containers in seconds. But that's an injector fault nothing to do with the seating surely!!!!!
Old Oct 2, 2013 | 08:22 PM
Harryh24's Avatar
Harryh24
in that case clean the seats with acetone on a rag on a stick makes it easier then new washers shouldn't need reseating
Old Oct 2, 2013 | 09:00 PM
GVK.'s Avatar
GVK.
I've been changing the injectors on these since, well ever since they started playing up, and never needed to re-cut the seats. Never seen any blowing either.
The Fiesta/Fusion/Mini/Citroen/French shit DW4/6, they blow, but they're a different engine altogether.
Old Oct 3, 2013 | 10:07 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Really? Delphi changed mine and didn't recut the seats. Surely if anyone would know it would be them?
Old Oct 3, 2013 | 10:20 AM
GVK.'s Avatar
GVK.
Ford ETIS (online workshop manual for all things Ford) doesn't mention it, or doing the leak offs at 2000rpm as I've seen mentioned on here too.
mark94
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
DavidK
Sep 27, 2015 02:55 PM
