cvh block
Old Sep 28, 2013 | 05:25 PM
stuart collins's Avatar
stuart collins
Default cvh block
are there any different casings that are thicker walled or are they all the same
Old Sep 28, 2013 | 06:13 PM
russ rs's Avatar
russ rs
Maybe try n/a block as had less stress??
Old Sep 28, 2013 | 11:47 PM
rsmark86's Avatar
rsmark86
i saw someone trying to sell a s1 block claiming its thicker walled than a s2
dont know how true this is, only way to tell is cut them up/ check them?
i got a low mileage xr2i bottom end needing bearings..... FOC?
only thing i know from research is a xr2i efi head is the best one too use when going big power due too being the best for larger valves, but nothing said about blocks.
this guy says to use a s1 block with s2 crank and oil pump but dont know how usefull he is.
Old Sep 29, 2013 | 12:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
AFAIK They are all the same thickness, as Mark says a low milage NA block will have seen far less heat cycles and a lower temperature range so will be less fatigued and less likely to crack.
Old Sep 29, 2013 | 12:40 PM
Red_bull's Avatar
Red_bull
A bit background.. Is the topic starter building a big bhp engine, but they keep cracking? Where?
Old Sep 29, 2013 | 12:45 PM
stuart collins
my block finally gave up sat nite 6in crack straight down the bore , 438bhp @27psi
Old Sep 29, 2013 | 12:50 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Didn't we all have a conversation on the strength of the cvh a while ago? Wasn't yours running sweet for 10+ years Stuart?
It may not be worth the money or hassle compared to a zetec build but what about engineered liners? Personally I wouldn't bother or know where to start but it's an option?
Old Sep 29, 2013 | 01:05 PM
stuart collins
mines been in he car 14 years, had to be machined straight as had twisted across the mains last year and now cracked , cant really complained its had some big power put through it , just a pain more than anything ,its all stripped and be machined this week , just wanted to now if any blocks where thicker
Old Sep 29, 2013 | 01:10 PM
Red_bull's Avatar
Red_bull
on which cylinder did it crack?
Old Sep 29, 2013 | 01:15 PM
stuart collins
2 I think
Old Sep 29, 2013 | 01:41 PM
SBT83's Avatar
SBT83
So what direction you gonna take now Stuart? You gonna source a decent cvh bottom end?
Old Sep 29, 2013 | 01:45 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
N/A is the best option as said, less heat cycles will be in your favor.
Old Sep 29, 2013 | 03:41 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
I was talking to someone the other day about cossie blocks, i know its a little off topic but touching back to the lining subject, this guy said having a cast block honed, lined and " nickel coated? " is the way forward. Expensive to do but will take huge bhp.
Anyone have any knowledge of this?
Old Sep 29, 2013 | 03:48 PM
SBT83's Avatar
SBT83
Originally Posted by DixieTheKid
I was talking to someone the other day about cossie blocks, i know its a little off topic but touching back to the lining subject, this guy said having cast block honed, lined and " nickel coated? " said is the way forward. Expensive to do but will take huge bhp. Anyone have any knowledge of this?
I'm sure it's Rod that's having the block lined? I maybe wrong. It's a good idea for big bhp. But for cvh? Be better going zetec.
Should be easy enough to find an xr2i cvh to use. Try not to twist it again Stuart
Old Sep 29, 2013 | 03:59 PM
escortmk3rwd's Avatar
escortmk3rwd
Blocks exactly same
Old Sep 29, 2013 | 04:16 PM
bennrst's Avatar
bennrst
Big power tho stu,y boy
Old Sep 29, 2013 | 04:19 PM
stuart collins
I will not be goin zetec
Old Sep 29, 2013 | 04:21 PM
stuart collins
we got loads of blocks
be going for machining next week
Old Sep 29, 2013 | 04:29 PM
SBT83's Avatar
SBT83
we got loads of blocks be going for machining next week
are you gonna use this as a point to push for more? Or is the previous setup ideal for what your after?
Old Sep 29, 2013 | 04:35 PM
stuart collins
theres more to come yet
Old Sep 29, 2013 | 04:48 PM
SBT83's Avatar
SBT83
Top Secret! Keep it under wraps mate
Old Sep 29, 2013 | 05:36 PM
mothrs2k's Avatar
mothrs2k
I may have commented on a pic of your car on facebook last week, saying how long it has lasted...wish I didnt bother now lol
Old Sep 29, 2013 | 06:39 PM
gus's Avatar
gus
why????
surely thats enough
Old Sep 29, 2013 | 07:46 PM
turbotrev's Avatar
turbotrev
I have a Series 1 block in my car, Karl told me at the time of the build that it is indeed a thicker walled than the series 2 block the car was originally fitted with, this may help you?
Although as previously mentioned ain't 400+hp enough!!!!??
Cheers Paul
Old Sep 30, 2013 | 12:49 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Karl who mate, Norris? If so then I would certainly take his word.
Old Sep 30, 2013 | 06:26 PM
turbotrev's Avatar
turbotrev
Yes buddy Karl Norris, sorry
Cheers Paul
Old Sep 30, 2013 | 07:15 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Learn't something new today then, good to know for anyone building a big power CVH these days
I imagine they are very very rare, do you know if it's just S1 blocks or any MK3 escort 1.6 CVH block?
Old Sep 30, 2013 | 08:02 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Sisters bf is a bit pedantic with Ford atuff and he said that series 1 blocks where different to the rest of the 1.6 cvh stuff.
And he also said that rs1600i's where built with ford "selected" parts (as near to perfect/the best produced)
Old Sep 30, 2013 | 08:04 PM
stuart collins
Cheers Paul
any numbers on the block mate
Old Sep 30, 2013 | 08:41 PM
little bram's Avatar
little bram
Can you not get liners for it stu?
Old Sep 30, 2013 | 08:45 PM
SBT83's Avatar
SBT83
I was talking to someone the other day about cossie blocks, i know its a little off topic but touching back to the lining subject, this guy said having a cast block honed, lined and " nickel coated? " is the way forward. Expensive to do but will take huge bhp. Anyone have any knowledge of this?
Old Sep 30, 2013 | 08:49 PM
little bram
Was just thinking if you can get the right bore size liner then could you not machine it down to fit the block?
Old Sep 30, 2013 | 08:59 PM
SBT83's Avatar
SBT83
I'd have thought you could. Dunno cost but I assume that's the process.
Would a n/a block be slightly stronger material or at least a denser material to help with the higher compression rather than low comp turbo block?
Daft question but I'll throw it out there
Old Sep 30, 2013 | 09:04 PM
little bram
Imo no the way I look at it is yeah its higher comp but the rs block has to cope with twice the power so needs to be stronger
Old Sep 30, 2013 | 09:13 PM
SBT83's Avatar
SBT83
Told you it was a daft question
Old Oct 1, 2013 | 05:19 AM
little bram
That's just my way of looking at it mate I mite be wrong.
Old Oct 1, 2013 | 01:57 PM
Skinny's Avatar
Skinny
is yours the awsome white one that was on jam sport stand if so awsome piece of kit mate
Old Oct 1, 2013 | 09:50 PM
turbotrev's Avatar
turbotrev
This is what my paperwork says...
Old Oct 1, 2013 | 09:53 PM
turbotrev's Avatar
turbotrev
Im afraid I'm not sure mate, guessing just S1 blocks? Karl would be the man to ask....
I'll have a look at the weekend Stu (the car is not at my home presently)
Cheers Paul
Old Oct 1, 2013 | 10:27 PM
wildheart's Avatar
wildheart
Karl told me some years ago that any CVH block upto 85 are the ones to go for.
