Rear Disc Brackets??
Old Sep 27, 2013 | 11:25 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
Default Rear Disc Brackets??
Has everyone stopped selling these?
cannot find any online anywhere (or am i not looking hard enough )
Old Sep 27, 2013 | 11:33 PM
RSmark84's Avatar
RSmark84
autospecialists sell these, unless they stopped producing them?
Old Sep 28, 2013 | 09:47 AM
Jamie_EscortSport
Have had a look and doesn't seem that they do anymore
Old Sep 28, 2013 | 09:49 AM
escortmk3rwd's Avatar
escortmk3rwd
to fit what ?
Old Sep 28, 2013 | 11:14 AM
Jamie_EscortSport
Rear calipers cossie
Old Sep 28, 2013 | 12:24 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
burton power do them mate, go to your local motor factor for an rs2000 handbrake cable. Get the bolts from burtons too otherwise you have to skim the tops.
Old Sep 28, 2013 | 12:30 PM
DixieTheKid
Pick-up P100 Power!
Kit
Brackets only
Old Sep 28, 2013 | 04:02 PM
RSmark84's Avatar
RSmark84
Here you go, found them on ebay for you Jamie:
http://www.ebay.co.uk/itm/FORD-ESCOR...item20d85fb07d
Old Sep 29, 2013 | 01:18 PM
Jamie_EscortSport
Cheers guys spot on! Time to get on this n get things sorted
Old Sep 29, 2013 | 04:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If your fitting them for improved braking then instead spend your money on some decent front brakes, fitting rear discs without big brakes up front means in an emergency stop situation the back locks up first like pulling the handbrake! Even with decent front brakes they mostly still lock up first.
If your fitting them for looks then be sure to use a bias valve and turn them down.
Old Sep 29, 2013 | 04:39 PM
DixieTheKid
Pick-up P100 Power!
I put 2wd calipers on my s2 all round. Worked very well. Made the std brakes feel completely shit. Bias valve would be ideal as it did get a little out of shape in the wet at times.
Old Sep 29, 2013 | 05:51 PM
RSmark84's Avatar
RSmark84
what percentage of front to rear on the bias valve is recommended? I've left mine at 50% as i've not drove the car since finishing the resto..... Would 10% at the rear be about right?
Old Sep 29, 2013 | 05:54 PM
DixieTheKid
Pick-up P100 Power!
Can't help you with that fella, didnt put one in mine.
Old Sep 29, 2013 | 08:22 PM
Jamie_EscortSport
Whilst the cars apart im gona get it all changed over as im re-doing all the brake lines etc, I am going to run a bias valve to the rear...and eventually upgrading the fronts!
Old Sep 30, 2013 | 11:47 AM
B19 JUB's Avatar
B19 JUB
was gonna swap the rears on my orion to discs but was told some scary stories about unbalanced and spinning.just upgraded fronts to 300mm with braided lines all round.its spot on
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossirob
Sep 3, 2015 09:17 PM
