Underside Coatings
Old Sep 27, 2013 | 04:12 PM
fiesta23's Avatar
fiesta23
Default Underside Coatings
I'm currently carrying out a bit of a resto on my escort rs turbo. At the moment its getting some welding then im planning on stripping back the underside to bare metal to give it all a new protective coating but at the moment im unsure what.
thought about a stone chip coating so I could get it sprayed body colour as it would look good but have been told the coating will not last as long as underseal and not protect from the elements as much
Looking for ideas on what's a good to coat it with and the pro's and con's.
The car will not be used during winter and will cover about 3000 miles a year probably less.
Old Sep 27, 2013 | 05:19 PM
Mark V8's Avatar
Mark V8
I've used this stuff but will be painting over it body colour
http://www.rust.co.uk/products/categ...chassis-paint/
Old Sep 28, 2013 | 01:52 PM
jaiscossie's Avatar
jaiscossie
I have just done mine with bilt hambers dynax ub which comes in large spray cans as gets really good reviews. I also used there s50 spray wax for in all the cavities
Old Sep 28, 2013 | 02:22 PM
fezzielove's Avatar
fezzielove
I have just done mine with a direct to metal offshore marine primer and paint, and then over the top with 2k very thick coating can be thinned down and sprayed, if it can stop rust in the north sea it should be good enough for a car underbody
Old Sep 28, 2013 | 04:33 PM
stevos's Avatar
stevos
You sure mate this is a ford we r talking about.
Good thread this as I will be looking at doing this to mine soon
Old Sep 28, 2013 | 09:54 PM
fezzielove's Avatar
fezzielove
Good point haha my car was a rust free celica, but on a serious note I have seen sea suction grates painted with this stuff that move hell of alot more water and air then the underside of a car will ever see in its life, failing that attach some sacrificial annodes to the underside haha
Old Sep 29, 2013 | 09:36 PM
Brian's Avatar
Brian
Can you paint over Bilt Hambers Dynax UB?
What about using the 3m sealer?
Brian
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
jonfoc
Sep 11, 2015 04:46 PM
