Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
timing issue on a fiesta 1.25 zetec
Old Sep 25, 2013 | 03:59 PM
Phil Munt's Avatar
Phil Munt
Default timing issue on a fiesta 1.25 zetec
Hi ,
My little festa goes like stink normally but lacks power on hills feels like timing not advancing altough i know this is controlled by the ecu but is there a sensor related to this. cheers.
Old Jan 15, 2014 | 07:28 PM
George_77's Avatar
George_77
Have you changed the timing belt recently? If yes there is a possibility that is not adjusted correctly...there is also a possibility that the cam sensor malfunctioning. If the cams timing is not correct then the cam sensor malfunctions also...So check the timing then the sensor, clean your throttle bodie and clean the injectors, then i believe you will be fine.
JoeyBoyden
Jan 4, 2024 02:36 PM
loughlin1
Ford Fiesta
Aug 20, 2015 10:42 PM
Botts
Aug 13, 2015 04:16 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
creator
Aug 2, 2015 12:24 PM
