code reader
i have a code reader for a efi xr3i, it had a triangle 3 pin plug on it. is there a reader for the frst with the 2 pin oval plug?
or a way to do flash tests?
Weird, all the early 90s Fords I've looked at on there all show a 3 pin triangular plug which 2 terminals are bridged and then the LED put between 2 of the terminals, can't see anything for a 2 pin plug :s I know they had a 2 pin plug as the original Ford diagnostic tool FDS2000 used the 2 pin 'serial link' connector on early Zetecs etc.
Trouble code identification
System code Code meaning Action
010 Separator/command code Briefly depress accelerator pedal fully
020 Command code Briefly depress brake pedal fully
030 Command code Briefly depress brake pedal fully
Flash type Fault location Probable cause
10 Cylinder 1, low Cylinder compression, ignition components, injector
20 Cylinder 2, low Cylinder compression, ignition components, injector
30 Cylinder 3, low Cylinder compression, ignition components, injector
40 Cylinder 4, low Cylinder compression, ignition components, injector
50 Cylinder 5, low Cylinder compression, ignition components, injector
60 Cylinder 6, low Cylinder compression, ignition components, injector
90 Cylinder balance test OK -
111 Systems OK -
112 Intake air temperature (IAT) sensor - voltage low Wiring, IAT sensor, ECM
113 Intake air temperature (IAT) sensor - voltage high Wiring, IAT sensor, ECM
114 Intake air temperature (IAT) sensor - range IAT sensor
116 Engine coolant temperature (ECT) sensor - range ECT sensor
117 Engine coolant temperature (ECT) sensor - voltage low Wiring, ECT sensor, ECM
118 Engine coolant temperature (ECT) sensor - voltage high Wiring, ECT sensor, ECM
121 Throttle position (TP) switch/sensor - range TP switch/sensor
122 Throttle position (TP) switch/sensor - voltage low Wiring, TP switch/sensor, ECM
123 Throttle position (TP) switch/sensor - voltage high Wiring, TP switch/sensor, ECM
124 Throttle position (TP) switch/sensor - voltage high Wiring, TP switch/sensor, ECM
125 Throttle position (TP) switch/sensor - voltage low Wiring, TP switch/sensor, ECM
129 Mass air flow (MAF) sensor/manifold absolute pressure (MAP) sensor - no signal change during throttle 'blip' Mass air flow (MAF) sensor/manifold absolute pressure (MAP) sensor
136 Heated oxygen sensor (HO2S) 2, bank 2 - weak mixture Wiring, HO2S, ECM
137 Heated oxygen sensor (HO2S) 2, bank 2 - rich mixture Wiring, HO2S, ECM
139 Heated oxygen sensor (HO2S) 2, bank 2 - weak/rich mixture Wiring, HO2S, ECM
144 Heated oxygen sensor (HO2S) 1, bank 1 - weak/rich mixture Wiring, HO2S, ECM
157 Mass air flow (MAF) sensor - voltage low Wiring, MAF sensor, ECM
158 Mass air flow (MAF) sensor - voltage high Wiring, MAF sensor, ECM
159 Mass air flow (MAF) sensor - range Wiring, MAF sensor, ECM
167 Throttle position (TP) switch/sensor - no signal change during throttle 'blip' TP switch/sensor
171 Heated oxygen sensor (HO2S) 1, bank 1 - adaptive limit reached Fuel pressure, wiring, air leaks, injectors, ECM
172 Heated oxygen sensor (HO2S) 1, bank 1 - weak mixture Wiring, HO2S, ECM
173 Heated oxygen sensor (HO2S) 1, bank 1 - rich mixture Wiring, HO2S, ECM
174 Heated oxygen sensor (HO2S) Wiring, HO2S, ECM
175 Heated oxygen sensor (HO2S) 2, bank 2 - adaptive limit reached Fuel pressure, wiring, air leaks, injectors, ECM
176 Heated oxygen sensor (HO2S) 2, bank 2 - weak mixture Wiring, HO2S, ECM
177 Heated oxygen sensor (HO2S) 2, bank 2 - rich mixture Wiring, HO2S, ECM
178 Heated oxygen sensor (HO2S) Wiring, HO2S, ECM
179 Fuel trim (part throttle) - weak mixture Fuel pressure, air leaks, injectors, ignition system
181 Fuel trim (part throttle) - rich mixture Fuel pressure, air leaks, injectors, ignition system
182 Fuel trim (idle) - weak mixture Fuel pressure, air leaks, injectors, ignition system
183 Fuel trim (idle) - rich mixture Fuel pressure, air leaks, injectors, ignition system
184 Mass air flow (MAF) sensor - air flow high Wiring, MAF sensor, ECM
185 Mass air flow (MAF) sensor - air flow low Wiring, MAF sensor, ECM
186 Injector pulse width - too long Wiring, injectors, ECM
187 Injector pulse width - too short Wiring, injectors, ECM
188 Heated oxygen sensor (HO2S), bank 2 - weak mixture Wiring, fuel pressure, injectors, air leak, HO2S, ECM
189 Heated oxygen sensor (HO2S), bank 2 - rich mixture Wiring, fuel pressure, injectors, air leak, HO2S, ECM
191 Heated oxygen sensor (HO2S), bank 2 - idle mixture weak Wiring, fuel pressure, injectors, air leak, HO2S, ECM
192 Heated oxygen sensor (HO2S), bank 1 - idle mixture rich Wiring, fuel pressure, injectors, air leak, HO2S, ECM
194 Heated oxygen sensor (HO2S) Wiring, HO2S, ECM
195 Heated oxygen sensor (HO2S) Wiring, HO2S, ECM
211 Profile ignition pick-up (PIP) signal Wiring, CKP sensor, ignition control (EDIS) module, ECM
212 Tachometer circuit Wiring, ignition control (EDIS) module, tachometer
213 Spark output (SPOUT) signal Wiring, ignition control (EDIS) module, ECM
214 Camshaft position (CMP) sensor - circuit malfunction Wiring, CMP sensor, ECM
215 Ignition coil 1, EDIS Ignition coil
216 Ignition coil 2, EDIS Ignition coil
217 Ignition coil 3, EDIS Ignition coil
218 Tachometer circuit Wiring, ignition control (EDIS) module, tachometer
222 Tachometer circuit Wiring, ignition control (EDIS) module, tachometer
226 Ignition control (EDIS) module - pulse missing Wiring, ignition control (EDIS) module, CKP/RPM sensor, ECM
227 Crankshaft position (CKP) sensor/engine speed (RPM) sensor Wiring, CKP/RPM sensor
228 Ignition control (EDIS) module/ignition coil 1 Wiring, ignition control (EDIS) module, ignition coil
229 Ignition control (EDIS) module/ignition coil 2 Wiring, ignition control (EDIS) module, ignition coil
231 Ignition control (EDIS) module/ignition coil 3 Wiring, ignition control (EDIS) module, ignition coil
232 Ignition coil primary circuit Wiring, ignition coil
233 Ignition control (EDIS) module Ignition control (EDIS) module
234 Ignition coil Ignition coil
235 Ignition coil Ignition coil
236 Ignition coil Ignition coil
237 Ignition coil Ignition coil
238 Ignition control (EDIS) module/ignition coil Wiring, ignition control (EDIS) module, ignition coil
239 Profile ignition pick-up (PIP) signal - PIP signal occurs when engine cranking Wiring, CKP/RPM sensor, ignition control (EDIS) module, ECM
241 Engine control module (ECM)/ignition control (EDIS) module - false data Engine control module (ECM), ignition control (EDIS) module
243 Ignition coil Ignition coil
311 Pulsed secondary air injection (PAIR) system Wiring, PAIR solenoid, MAP/MAF/VAF sensor, ECM
312 Pulsed secondary air injection (PAIR) system Wiring, PAIR solenoid, MAP/MAF/VAF sensor, ECM
313 Pulsed secondary air injection (PAIR) system Wiring, PAIR solenoid, MAP/MAF/VAF sensor, ECM
314 Pulsed secondary air injection (PAIR) system Wiring, PAIR solenoid, MAP/MAF/VAF sensor, ECM
315 Pulsed secondary air injection (PAIR) system Wiring, PAIR solenoid, MAP/MAF/VAF sensor, ECM
316 Pulsed secondary air injection (PAIR) system Wiring, PAIR solenoid, MAP/MAF/VAF sensor, ECM
326 Exhaust pressure (EP) sensor Wiring, EP sensor, ECM
327 Exhaust pressure (EP) sensor/exhaust gas recirculation (EGR) solenoid Wiring, EP sensor, EGR solenoid, ECM
328 Exhaust gas recirculation (EGR) solenoid Wiring, EGR solenoid, ECM
332 Exhaust gas recirculation (EGR) solenoid Wiring, EGR solenoid, ECM
334 Exhaust gas recirculation (EGR) solenoid Wiring, EGR solenoid, ECM
335 Exhaust pressure (EP) sensor Wiring, EP sensor, ECM
336 Exhaust pressure (EP) - high EP sensor
337 Exhaust pressure (EP) sensor/exhaust gas recirculation (EGR) solenoid Wiring, EP sensor, EGR solenoid, ECM
338 Engine coolant temperature (ECT) sensor - temperature low Wiring, ECT sensor, ECM
339 Engine coolant temperature (ECT) sensor - temperature high Wiring, ECT sensor, ECM
341 Octane plug - connected to earth Octane plug
411 Engine rpm too low during self-test Wiring, compression, ignition, IAC valve, ECM
412 Engine rpm too high during self-test Wiring, compression, ignition, IAC valve, ECM
413 Idle air control (IAC) valve Wiring, IAC valve, ECM
414 Idle air control (IAC) valve Wiring, IAC valve, ECM
415 Idle air control (IAC) valve Wiring, IAC valve, ECM
416 Idle air control (IAC) valve Wiring, IAC valve, ECM
452 Vehicle speed sensor (VSS) Wiring, VSS, ECM
511 Engine control module (ECM) - ROM error ECM
512 Engine control module (ECM) - KAM error ECM
513 Engine control module (ECM) - internal reference voltage ECM
519 Power steering pressure (PSP) switch - not activated during self-test Wiring, PSP switch
521 Power steering pressure (PSP) switch - not activated Wiring, PSP switch
522 Park/neutral position (PNP) switch - circuit malfunction Wiring, PNP switch, ECM
523 Park/neutral position (PNP) switch - circuit malfunction Wiring, PNP switch, ECM
528 Clutch pedal position (CPP) switch - circuit malfunction Wiring, CPP switch, ECM
536 Brake pedal position (BPP) switch - not activated during self-test Wiring, BPP switch, ECM
538 Operator error during self-test -
539 AC switched ON during self-test Wiring, AC switch
542 Fuel pump - circuit malfunction Wiring, fuel pump relay, IFS switch
543 Fuel pump - circuit malfunction Wiring, fuel pump relay, IFS switch
551 Idle air control (IAC) valve - circuit malfunction Wiring, IAC valve, ECM
552 Pulsed secondary air injection (PAIR) system - circuit malfunction Wiring, PAIR solenoid
556 Fuel pump - circuit malfunction Wiring, fuel pump relay
558 Exhaust gas recirculation (EGR) solenoid - circuit malfunction Wiring, EGR solenoid, ECM
563 Engine coolant blower motor relay - circuit malfunction Wiring, engine coolant blower motor relay
564 Engine coolant blower motor relay - circuit malfunction Wiring, engine coolant blower motor relay
565 Evaporative emission (EVAP) canister purge valve - circuit malfunction Wiring, EVAP canister purge valve, ECM
566 3rd/4th gear shift solenoid Wiring, 3rd/4th gear shift solenoid
573 Engine coolant blower motor relay - circuit malfunction Wiring, engine coolant blower motor relay, ECM
574 Engine coolant blower motor relay - circuit malfunction Wiring, engine coolant blower motor relay, ECM
575 Fuel pump/inertia fuel shut-off (IFS) switch - circuit Wiring, fuel pump relay, IFS switch
576 Kick-down switch Wiring, kick-down switch
577 Kick-down switch - not activated during self-test Wiring, kick-down switch
612 Transmission range (TR) switch, 4th/3rd gear switch contacts - open circuit Wiring, TR switch
613 Transmission range (TR) switch, 4th/3rd gear circuit - open circuit Wiring, TR switch
614 Transmission range (TR) switch, 3rd/2nd gear circuit - short circuit Wiring, TR switch
615 Transmission range (TR) switch, 3rd/2nd gear switch contacts - open circuit Wiring, TR switch
621 Shift solenoid (SS) 1 - circuit malfunction Wiring, shift solenoid, ECM
622 Shift solenoid (SS) 2 - circuit malfunction Wiring, shift solenoid, ECM
624 AT electronic pressure control solenoid AT electronic pressure control solenoid
625 AT electronic pressure control solenoid - circuit malfunction Wiring, AT electronic pressure control solenoid, ECM
628 Modulated torque converter clutch (TCC) solenoid Wiring, TCC solenoid
629 Torque converter clutch (TCC) solenoid Wiring, TCC solenoid
634 Park/neutral position (PNP) switch Wiring, PNP switch
635 Transmission fluid temperature (TFT) switch - circuit malfunction Wiring, TFT switch, ECM
636 Transmission fluid temperature (TFT) switch - circuit malfunction Wiring, TFT switch, ECM
637 Transmission fluid temperature (TFT) switch - circuit malfunction Wiring, TFT switch, ECM
638 Transmission fluid temperature (TFT) switch - circuit malfunction Wiring, TFT switch, ECM
639 Turbine shaft speed (TSS) sensor - signal low Wiring, TSS sensor
645 1st gear failure - incorrect ratio Wiring, transmission fault
646 2nd gear failure - incorrect ratio Wiring, transmission fault
647 3rd gear failure - incorrect ratio Wiring, transmission fault
648 4th gear failure - incorrect ratio Wiring, transmission fault
649 Electronic throttle valve - failure Wiring, electronic throttle valve, ECM
651 Electronic throttle valve - intermittent failure Wiring, electronic throttle valve, ECM
652 Modulated torque converter clutch (TCC) solenoid - circuit malfunction Wiring, TCC solenoid, ECM
653 Transmission control switch - not activated during self-test Wiring, transmission control switch, ECM
658 Performance/economy switch - not activated during self-test Wiring, performance/economy switch, ECM
998 ECT sensor/IAT sensor/MAF sensor/TP sensor - circuit malfunction Wiring, ECT sensor/IAT sensor/MAF sensor/TP sensor, ECM
111 Systems OK -
Is it a Gunson reader from Halfords?
Found the instructions here on a PDF
http://www.gunson.co.uk/items/pdf/Pr...4160_G4152.pdf
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Si B
Sep 12, 2015 06:49 AM
