Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
TDDi EGR Delete
Old Sep 21, 2013 | 06:14 PM
Cardie's Avatar
Cardie
Default TDDi EGR Delete
Noticed the other day the 3 wires going to the EGR have been cut on my Focus TDDi, I would guess that should throw up a code and put the engine light on straight away? If so is it possible its been 'mapped out'. It hasnt had any other work done as its slow and the cat is still on and doesnt look like its been touched.
Car runs fine!
It doesnt have a blanking plate on it, is it worth putting one on? Im guessing the EGR is constantly closed if its not plugged in?
Thank you!
Old Sep 21, 2013 | 06:18 PM
GVK.'s Avatar
GVK.
The 3 wires are for the EGR level/height sensor, they don't operate it, it's operated by the vacuum pipe, there's a solenoid on the bulkhead just behind the EGR valve that controls it.
Old Sep 22, 2013 | 01:01 PM
Cardie's Avatar
Cardie
But still if its not picking up any feedback fromt he EGR shouldnt it put the engine light on? Also why would someone cut them instead of blanking it off?
Would blocking the vacuum pipe do the same as fitting a blanking plate or would it be open all the time if I blocked the vacuum line?
Old Sep 22, 2013 | 02:16 PM
GVK.'s Avatar
GVK.
There will be a fault code logged, but not probably enough of an important fault to put the light on.
Those wires can get damaged with engine movement, not necessarily cut.
Vacuum opens it, so it will be closed with the vac line blocked.
Old Sep 22, 2013 | 05:59 PM
Cardie's Avatar
Cardie
They have been clearly 'cut' then shoved out of the way. The Dash says No DTC.
Cheers.
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
