Whats the issue here then?
Asking for a friend.
This is a Golf MK4 TDi
Going along you can hear a slight knocking/rattling/grinding sound at lower speeds and on bumpy roads from drivers side front.
Check the balljoint, trackrod, bushes , usual stuff etc for play, nothing.
Put the car in neutral , jack the drivers side up and jerk the wheel forward in direction of travel or in reverse and it makes this sound -
http://tinypic.com/player.php?v=2njv...5#.Ujtiy8Y3uSo
Is this dead cv joint or worse?
Car drives fine, goes into gear fine?
I thought if the wheel bearing had gone there would be massive amounts of play in the wheel and an interesting driving experience, ( a friend ended up half a mile into a farmers field when his bearing let go at 60mph a few years back lol ) it drives fine, just this odd noise as said, knocks/rumbles/grinds/clunks etc
SMILER258
Sep 28, 2015 09:04 AM
