escort efi
Old Sep 17, 2013 | 10:44 PM
chrisgcombi's Avatar
chrisgcombi
Default escort efi
hi , I have an escort efi engine , could anyone tell me if I can fit twin 40 webbers on this . thanks
Old Sep 18, 2013 | 06:10 AM
rsmark86's Avatar
rsmark86
in a nut shell....... not with out alot of work
ignition management to run coilpack set up with external trigger wheel
different fuel lines and fuel pump and fuel reg
carb cam
and many other bits........
if you are serious about it, fit a carb head, carb dizzy, and facet fuel pump and filterking fuel reg, with return blocked up
Old Sep 18, 2013 | 05:05 PM
chrisgcombi
thanks for that m8 , think I will give that one a miss - sounds like to much work for me . I was after more power , do u think I would be better zetec as apparently I can still use efi loom etc .
Old Sep 18, 2013 | 09:15 PM
rsmark86's Avatar
rsmark86
Just use everything zetec, loom, ecu the lot, much better way of doing it
Or throttle bodies?, could see if the boost monkeys ofam ecu fits your efi loom, that way it's fully mappable to fit throttle bodies
Dr. Ickxs
Sep 15, 2015 10:15 PM
RSmark84
Sep 13, 2015 01:29 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
bigryrs
Sep 7, 2015 06:45 PM
