st200 lmrc mods?
Old Sep 16, 2013 | 10:33 PM
kieranmondeo's Avatar
kieranmondeo
Default st200 lmrc mods?
Any way you can keep lmrc operating on mondeo 2.5L V6 mondeo to keep car constantly on 24 valves?
Old Sep 17, 2013 | 12:41 AM
anodised's Avatar
anodised
it always runs as 24v the imrc are flaps in the lower inlet which open up after so many rpm
nothing to do with the valves
Old Sep 17, 2013 | 05:22 AM
A good mod you can do is remove the control unit from on top of the engine to the battery tray.
Old Sep 17, 2013 | 06:52 AM
kieranmondeo
What difference will that make?
Old Sep 17, 2013 | 09:15 AM
3dr cossie's Avatar
3dr cossie
stops it overheating which in turn stops it working
cheers Matthew
Old Sep 17, 2013 | 11:15 AM
Thank you Matthew.
Old Sep 17, 2013 | 11:23 AM
mondeoman81's Avatar
mondeoman81
as said above mate relocating it..... are you having problems
Old Sep 17, 2013 | 07:13 PM
kieranmondeo
Yes sometimes.. I thought it was just heat from traffic at first engine struggling to get cold air but it will do it in middle of night in middle of know where.. basically at 3 1/2 thou revs it should take off noticably with almost a boost feeling, but it seems to struggle to boost, sometimes only just starting to boost as its nearly red lining..
Old Sep 18, 2013 | 12:13 AM
kieranmondeo
Any idea?
Old Sep 18, 2013 | 06:41 AM
kyle_st200's Avatar
kyle_st200
Probably the control unit overheating as said above, try relocating it I had to do this on mine
Old Sep 18, 2013 | 06:19 PM
kieranmondeo
Ok how do you fix it down though?
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
