Escort RST black NMS series 2 ***** NOW SOLD!!*****
Old Sep 16, 2013 | 10:08 PM
turbotrev's Avatar
turbotrev
Default Escort RST black NMS series 2 ***** NOW SOLD!!*****
It is with great sadness that after around 8 years of ownership I'm putting my Series 2 RST up for sale, I've got almost as far as I can with the car and the need for another Cosworth is calling me!
I originally bought the car as a standard un-modded example with the intention of starting to mod it from scratch, the car was stripped to a rolling shell and taken to a local bodyshop where it had new front wings, front panel, rear quarter panels, inner and outer sills, charisma rails, spare wheel well removed, filler cap removed, de-locked doors and boot, scuttle smoothed, as well as all signs of other rust removed.
It was then painted inside, outside and under the bonnet, while the underside was under sealed, all bumpers smoothed and modded, DTM style mirrors, 90 spec spoiler, etc.
I do have photos of all the body restoration work at various stages so will get the photos scanned and added during the week (photos are in the loft somewhere). Total cost of the bodywork was 3.5k but I don't have any receipts for that unfortunately.
While the body was being done the engine was shipped off to Norris Motorsport for a 1600 stage 7 conversion to be carried out. This was all in late 2005, after the running in miles were done it was finally mapped by Karl.
The car was used for a few years then was left garaged and not in use for over 4 years.
I recently changed the car about a bit (removed its graphics, new wheels, seats, put some interior back in, new lights, changed some mods and added parts I wanted to do previous) and was then put back on the road at the beginning of this year to use for the summer.
Spec is....
Engine: NMS Stage 7 1600cc cvh engine. Comprising of S1 thick walled block, S1 crankshaft, steel rods with arp bolts, forged cosworth pistons, hp oil pump, stage 4 NMS cylinder head, bigger valves, custom camshaft, vernier pulley, hybrid T34 turbo with .55 housing, cosworth management conversion, green injectors, level 6 ecu, double cosworth custom intercooler, reverse charge carrier, ERL water injection, Bosch 004 fuel pump, group A coil, Samco boost and coolant houses, Baily header tank and oil breather, group A air filter, Mocal oil cooler, mongoose exhaust, Pro-Alloy radiator,
Transmission: CTS stage 2+ gearbox with shot peened gears and Quaife ATB diff, vibratechnics gearbox mounts, AP 4 paddle clutch, B&M quick shift, mk5 escort clutch pedal conversion.
Suspension: AVO coilovers on front, AVO shocks and springs on rear, rear strut brace, front adjustable lower arms, poly bushed throughout.
Brakes: front High-Spec 285mm grooved discs with 4-pot calipers and green stuff pads, rear cossie 2wd disc conversion, braided brake hoses, ABS removed, dot 5 fluid.
Body: De-locked all round, bumper strips removed, bonnet raised at rear, scuttle smoothed, single wiper, rear wiper removed, polycarbonate rear and side rear windows, fuel filler in N/S window, original amber lights all round, Laguna front splitter, DTM door mirrors, front glass clear windows, spare wheel well removed, Toad alarm, debadged bonnet, aero catch bonnet catches.
Wheels: Pro Race 1.2 17x7.5 alloys, refurbished in gloss black with Toyo R888 tyres, locking bolts.
Interior: rear stripped out, full Rollcentre cage with one diagonal, rear strut brace, custom fuel filler pipe work (using original tank), Orion mk1 boot solenoid, keyless starter, suede steering wheel, Pro-comp rev counter, cosworth speedo conversion (170mph) inc act gauge, cobra evolution bucket seat, standard passenger Recaro seat (other original seat available but bottom has broken), Luke harnesses, Glow Shift boost gauge.
I think that's about it, there may be a few other bits I've missed, I have receipts for virtually all the parts I've bought, and the the engine conversion and gearbox (just them two bills total over 8.5k), the engine and gearbox have covered just short of 4,000 miles without any problems, engine and gearbox oil changed regularly, Mobil 1 Motorsport, synthetic gear oil, always run on Shell super unleaded.
The car has run a 13.2 quarter @ 110mph at Santa Pod with slips to prove (more in it too as my launches were rubbish!)
Has attended the 2007 Performance Ford thrash where I drove there, ran and drove home with no issue's, car has never let me down and always been reliable,
Here it achieved at 157mph top speed run (before running out of runway)
Was featured in Performance Ford Mag January 2007.
Has also just been rolling roaded at Surrey Rolling Road, producing 286bhp and 300lb ft torque at 1.7 bar of boost, operator mentioning its fuelling and running perfectly.
Bad bits: Where the bonnet has been debadged the paint has started to distort now, ideally would need the front of the bonnet painted, all the wheel arches are stone chipped and the rears quite bad, small stone chips on front bumper, sump is dented on the very back where a driveshaft snapped years ago (only cosmetic, doesn't affect running whatsoever ever), os inner driveshaft gaiter split slightly (temporarily repaired for now)
I may even get some of these small bits sorted out, nothing major so just trying to be honest
For any further info or questions feel free to drop me a call or a text message (message is probably easier in the day as I can't always answer the phone at work) on 07930 421 301 or PM me on here, I'm not in a desperate need to sell and if I need to will keep the car so no silly offers, time wasters or part ex's please....
Ł6500 ovno
Attached Thumbnails Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps82736bd6.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps4706cc21.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps9d73b5fc.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps1f277e46.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps5f65486f.jpg
Old Sep 16, 2013 | 10:12 PM
turbotrev's Avatar
turbotrev
A few more pics...
Attached Thumbnails Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps7b57a4f8.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps509a8393.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zpsf43bfc06.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps14e8d996.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zpsb551b8ef.jpg
Old Sep 16, 2013 | 10:15 PM
turbotrev's Avatar
turbotrev
And some more....
Attached Thumbnails Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps1f4013d1.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zpsf47b8c7e.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps71a80466.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zpsb551b8ef.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-image_zps668f73ff.jpg
Old Sep 16, 2013 | 10:17 PM
turbotrev's Avatar
turbotrev
And a couple of the resto pics...
Attached Thumbnails Escort RST black NMS series 2 ***** NOW SOLD!!*****-eng3.jpg   Escort RST black NMS series 2 ***** NOW SOLD!!*****-eng4.jpg
Old Sep 16, 2013 | 10:50 PM
Cossie.jack's Avatar
Cossie.jack
Looks gorgeous that!!!
Old Sep 16, 2013 | 10:58 PM
rs old skool's Avatar
rs old skool
wow! looks fantastic! its pretty much my cars twin .. mine was featured in fast ford few months back.. any way good luck with the sale
Old Sep 16, 2013 | 11:02 PM
Rst tyrone's Avatar
Rst tyrone
zetec turbo
Very nice mate is there any movement on the price bud ??
Old Sep 17, 2013 | 12:25 AM
rsmark86's Avatar
rsmark86
serious spec car for the money
glwts
Old Sep 17, 2013 | 03:42 PM
3doorcozmess's Avatar
3doorcozmess
Hi Paul make sure it goes to a good home i know how much time you have spent on this car as well as money, good luck with the sale.
Who ever gets the car will love it, it's a rocket.
Si.
Old Sep 17, 2013 | 04:55 PM
turbotrev's Avatar
turbotrev
At the moment not really.... come and have a look at it, you won't be disappointed...
Cheers Paul
Old Sep 17, 2013 | 09:26 PM
Rst tyrone's Avatar
Rst tyrone
zetec turbo
6k cash and im there mate ill even treat you to a Mc Donald's while im there lol
Old Sep 18, 2013 | 09:12 AM
turbotrev's Avatar
turbotrev
Not quite but nearly there buddy....
A few more pennies and you'll be there... And I'll still have a Mc Donald's please 👍
Old Sep 26, 2013 | 05:56 AM
3doorcozmess
Hello Paul have you sold the beast yet?
Si
Old Sep 26, 2013 | 05:12 PM
turbotrev's Avatar
turbotrev
No not yet mate. Ebay and Pistonheads time soon i think...
Forgot to mention its taxed till the end of October and MOT'd until April 2014
Cheers Paul
Old Oct 11, 2013 | 09:02 AM
turbotrev's Avatar
turbotrev
Still need to dig out the restoration photos but it will happen!
Also dropping the price to 7k OVNO
Will be going on the bay soon too
Cheers Paul
Old Nov 5, 2013 | 06:40 AM
3doorcozmess
Hi Paul
Just looked at your pictures you only have one seat in the front? when I saw your car at an old skool ford meet correct me if I'm wrong I thought I saw two seats.
Si
Old Nov 17, 2013 | 07:30 PM
turbotrev's Avatar
turbotrev
Yes your correct mate, the car now has the standard recaro seat fitted to the passenger side, the drivers side recaro will also come with the car, both are in excellent condition.
Price now Ł6500 ovno
Cheers Paul
Old Nov 25, 2013 | 12:06 AM
jonny s2's Avatar
jonny s2
blimey i cant believe your selling this paul
GLWTS its an impressive machine, someone will have a BARGAIN
Old Nov 28, 2013 | 05:25 PM
turbotrev's Avatar
turbotrev
It's kind of cos I need too mate, wanna put the money into a cosworth, if I could afford both I'd keep it!
Cheers Paul
Old Dec 21, 2013 | 09:57 AM
turbotrev's Avatar
turbotrev
Sad to say but the car is now sold!!
Cossie power next year though!
Cheers Paul
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Aug 17, 2015 09:06 PM
Bart
Aug 9, 2015 09:04 AM
dlwarrior
Aug 5, 2015 10:19 AM
