Diesel Injector Specialist
Old Sep 15, 2013 | 07:29 AM
Brian's Avatar
Brian
Default Diesel Injector Specialist
Can anyone recommend a decent diesel injector specialist in or near Essex?
I took my Mondeo TDCi to a place in Tilbury and had 4 reconditioned injectors fitted and a year to the day they went again I took it back they sorted it out and said if they go a again I'm going to have to charge you and they are going again
I can remove them myself so could also possibly send them away?
Cheers Brian
Old Sep 15, 2013 | 07:39 AM
55rsturbo's Avatar
55rsturbo
might be too far, but i get kent diesel center in maidstone to fit mine, they are a part of Haynes so might be a bit dear. cheers frankie
Old Sep 15, 2013 | 05:32 PM
Big AL's Avatar
Big AL
M & C Diesels, Langham, 30 seconds from the A12 North Colchester.
They've done injectors and fuel pump on a mates Mondy and he was well pleased, another mate sent his Zaf there for a DPF delete and they said it didn't need it although they could have just done it and taken his money. My mechanic recommends them and sends bits and pieces to them.
http://www.mandcdiesel.co.uk/Site/mcajax.php
Old Sep 15, 2013 | 05:38 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
First diesel Croydon
Old Sep 15, 2013 | 07:04 PM
focus 4x4's Avatar
focus 4x4
Colchester fuel injection are different class mate , you won't go wrong with them
Old Sep 15, 2013 | 07:10 PM
jamie's's Avatar
jamie's
if its going thru injectors so much there may be an underlying issue
the fuel pumps are common for breaking up internaly and throwing out tiny metal shavings
which gets cought up in the injectors and kills them
Old Sep 16, 2013 | 12:13 PM
Brian's Avatar
Brian
Thanks guy's I will give the place a call and have a chat
It could be something else like the pump breaking up but how can I check?
Brian
Old Sep 16, 2013 | 04:32 PM
jamie's's Avatar
jamie's
hard to tell realy, but you sometimes get tiny metal filings in the fuel filter
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
