1984 (B) mk2 fiesta & 1985 (C) mk2 fiesta
Sep 14, 2013 | 06:48 PM
Hi all
i picked up this
for £30
Sep 14, 2013 | 07:09 PM
Sep 14, 2013 | 07:18 PM
Sep 14, 2013 | 07:27 PM
Seams pretty straight good project
Sep 14, 2013 | 07:31 PM
Quote:
Originally Posted by
gingerturbo
its one of the best shells i have seen, and i have got a whole 1985 mk2 to pick up so thats all my bits sorted
Sep 14, 2013 | 07:35 PM
Sounds good what's the plans monster mk2 or full restore
Sep 14, 2013 | 07:41 PM
this one is full restore, but the 85 is monster, im toying with choping it into a pickup, and thinkin 2.1 zvh turbo
Sep 15, 2013 | 07:14 PM
Sep 15, 2013 | 08:26 PM
tlsjk
That'll be cool
Sep 16, 2013 | 08:10 AM
thanks for the replys any feedback/ideas for the 85 welcome
more pics soon....
now off to the garage to play
Sep 16, 2013 | 03:23 PM
cleaned up the holes in the boot
it looks like its had a new rear panel at some point
Sep 18, 2013 | 07:20 PM
update time again
i have been busy doing more cleaning up
as you can see the boot floor has seen better days, but it nothing that can't be fixed
then out came the mig
first was the wing tops
then the inner wings
and last i started the boot (drivers side)
i still need to clean up all the welds but looking good evan if i do say so myself.
Sep 22, 2013 | 08:45 AM
i finished the inside of the boot (pic's to come soon) and decided to weld the under-side too
it dont look too good but it will do the job
then time to do the off side
then the arch and sill got cleaned up
thats it for now more to come soon
Sep 22, 2013 | 08:49 AM
Can't grumble at 30 smackers!
Forget the ZVH, just go full Zetec.
Sep 22, 2013 | 09:03 AM
CrOwSoN15
i was only going zvh to cut out the ecu
and £30 is good but i got the C reg for free, its done 5270 miles from new but the shell has got more rot so gonna put the bits in this one.
then when its striped it getting the chop
Sep 22, 2013 | 11:17 AM
Do the same with a Zetec, run it on Megajolt with bike carbs.
Sep 22, 2013 | 06:20 PM
Sep 22, 2013 | 06:26 PM
You can run a zetec on carbs using a ESC module/loom from a fiesta/escort
Sep 22, 2013 | 06:31 PM
looks like its going to be a zetec then
Sep 22, 2013 | 06:34 PM
You get a nice power gain from a zetec and pretty cheap to build
Sep 22, 2013 | 06:38 PM
i can get a 2.0 bottom end for free all good if i was going zvh
Sep 22, 2013 | 06:42 PM
You can get a running 2.0 Mondingo for a couple of hundred, everything you need! Bar the sump and flywheel.
Sep 22, 2013 | 06:50 PM
tlsjk
Get that as a spare or build that bottom end to suit a zetec turbo incase a 2.0 on carbs ain't powerful enough
Sep 22, 2013 | 06:57 PM
i was thinking of doing a 2.1 turbo but a 2.0 should be ok in it as there is no weight in a mk2 lol
Sep 22, 2013 | 06:59 PM
Sometimes you can't help it as a lot of the pistons you get on a budget are suited for a bigger bore so once you over bore to suite it ends up as a 2.1
Sep 22, 2013 | 07:00 PM
As above, if you go forged internals you'll end up being nearer 2.1 anyway after machining.
I didn't think you wanted to bother with aftermarket ecu though?
Sep 22, 2013 | 07:03 PM
i was told you can use calibra pistons
Sep 22, 2013 | 07:04 PM
Indeed, C20let pistons is a tried and tested route but still need plenty of machining doing.
i want it as basic as possible really
Sep 22, 2013 | 07:05 PM
machining dont bother me as i know a good shop
Sep 22, 2013 | 07:07 PM
I've got Z20 LET pistons for sale as I was building a zetec turbo and the only machining you need to do is an overbore, and to machine the piston to suite the zetec small end unless you feel like machining both piston and rod to suite 22mm cosworth small end
Sep 22, 2013 | 07:09 PM
If you want basic, just buy an ST170 bottom end, black top head with ST170 valve springs, FRS inlet and exhaust inc turbo and management to suit.
Sep 22, 2013 | 07:16 PM
CrOwSoN15
Yeh as said you wouldn't really need any more in a fiesta
Sep 22, 2013 | 07:29 PM
gingerturbo
how much you asking?
and i know st170 is all i would need but i might want more :lamo:
Sep 22, 2013 | 07:32 PM
An ST170 bottom end will just about do 350bhp, without a good stiff chassis it'll pull a mk2 apart lol.
Sep 22, 2013 | 07:33 PM
£80 for them and there good for 300bhp
Sep 22, 2013 | 07:39 PM
CrOwSoN15
the chassis is getting stiffened as it needs to be if i chop it.
Sep 22, 2013 | 07:42 PM
gingerturbo
i will keep it in mind but i wanna get the body done befor i think about engine too much
Sep 22, 2013 | 07:44 PM
No worries there not hard to come by if I do sell them
89barto89
Oct 4, 2015 06:59 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
Steve Escos
Oct 1, 2015 06:57 AM
Sp3no
Sep 27, 2015 07:23 PM
