Need help quick
Old Sep 12, 2013 | 12:18 PM
CapriChris's Avatar
CapriChris
Default Need help quick
Hi my brake callipers are screwed need some new ones its a 1987 capri 2litre front callipers I'm in Devon and having trouble finding them also do the 2.8i callipers fit ????
Old Sep 12, 2013 | 01:23 PM
Danwood79's Avatar
Danwood79
You want to be looking for these numbers
Brake Engineering CA138 & CA138R
XL XC80284 & XC80285
Remy DC80284 & DC80285
Lucus BCW168 & BCW169
I think the calipers from a 2.8 would be different because of the different disc sizes and thickness.
Hope this helps.
Dan
Old Sep 12, 2013 | 01:32 PM
CapriChris's Avatar
CapriChris
I have spoken to spoken to the bloke that has the 2.8 calipers an he said they will go straight on and they're m16s :/ bit confused tbh
Old Sep 12, 2013 | 01:44 PM
Danwood79's Avatar
Danwood79
Just had a look in a brake book and the Discs for a 2.0 are 245 diameter solid disc with a 27mm offset and the 2.8 are 245 vented 32mm offset and 2 of the caliper books say they are different.
Only way to be sure is to offer them up as it may only be the caliper carrier what is different.
Im only going by aftermarket books.
Someone else might be able to put us right.
Dan
Old Sep 12, 2013 | 02:00 PM
CapriChris's Avatar
CapriChris
Cheers for your help bud I will see if I can find anything else out
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
