Non permanent tiger seal type adhesive?
Evening all
I am looking for some adhesive to fit a body skirt kit. The kit itself its held quite securely by clips and screws, however they suggest a sealant/adhesive is also used to keep the crap out and stop it going out of shape I guess.
I have used tiger seal in the past and it is brilliant but is a bit too permanent. Is there anything else on the market that is similar but is easily removable?
I have looked at trim tapes however I am unsure of what thickness I would need, I wouldn't want the kit to stand proud of the body work with a thick layer of foam tape in between.
Thanks
Rich
Thanks
Rich
you could try some butyl tape. i use it at work and is quite strong (but not to the point its impossible to remove)and forms a good seal. it comes in different thicknesses so you can get your preffered look
if the tape starts to lose its stickyness then it will look crap - mine did this so i used tiger seal to sort it out. wished i used it in the first place. holds any out of shape skirts in place too!
