which electronic boost controller ?
Old Sep 10, 2013 | 02:48 PM
s1cab's Avatar
s1cab
Default which electronic boost controller ?
What's the aem tru boost like anyone used it ? What do you use ?
Old Sep 14, 2013 | 07:53 AM
wide ka's Avatar
wide ka
yes i use it, works fine easy to use ive found and fits in nicley with the rest of there gauges
Old Sep 14, 2013 | 08:05 AM
s1cab's Avatar
s1cab
Sounds good thanks
Old Sep 14, 2013 | 08:16 AM
grant_xr's Avatar
grant_xr
Remember to get your car set up after fitting it mate.
STU from MSD put up a post showing how much it alters the map if you change from an amal or bleed valve to eelctronic boost comtrol.
Could potentially melt your engine!
Grant
Old Sep 15, 2013 | 07:39 AM
Karlos G's Avatar
Karlos G
Balls Deep!
If money allows then an Apexi AVC-R is an awesome piece of kit.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
