1990 s2 rs turbo efi
Old Sep 10, 2013 | 02:17 PM
beemer1664's Avatar
beemer1664
Default 1990 s2 rs turbo efi
Im selling my car purely as it never gets used and just sits in my garage, since iv owned her since last October she has been garaged and totally changed in everyway possible heres a list of what iv purchased in the last few months!
Escort Cosworth Alloys with brand new tyres
Carbon Fibre Bonnet with aero catches
Smoked rear lights
Bigger brakes grooved and drilled discs with painted white calipers
Show cage
Fully flocked interior
Prosport digital gauges boost, volts, water temp, oil temp
Momo snap off steering wheel (can easily be removed for extra security Full sound system including custom front speaker pods, rear stealth shelf with 6x9, 2 x 10" subs in boot with matching amp in custom boot build all powered off a pioneer dvd touchscreen head unit
Shes had a efi engine conversion Stage 2 t3 turbo Airtec rad and intercooler with twin fans Full scorpion Exhaust
New front wishbones
K&N air filter with custom stainless steel pipework
Blue samco hoses
rear strut brace
Uprated fuel pump
Mirror inlet manifold
Mirror wiper motor cover, fusebox cover, suspension turrets and brake resovoir bottle
The engine has had new valve stem seals, tappets, piston rings, big end bearings all purchased from burton, also lower temp thermostat and fan switch, beige injectors, msd chipped ecu, new water pump, tensioner and cambelt, new oil and filters and plugs!
After car was built it went to devil developments to be set up it was setup but when he upped the boost the clutch started to slip I was gutted so next on my list was to buy an organic clutch but its stopped at that point! At the moment the boost is turned down to allow the clutch to live its still bloody quick but not at its full potential Car has 5 months tax and 8 months mot
Bad points! Wheels have slight kerbing marks as I got them but this is because tryes are stretched over Slight bubbling around sunroof, this car is mint underneath and it has not seen an inch of welding underneath all inspection is welcomed Battery tray has been professionally replaced but only sprayed in primer to prevent rusting my idea was to spray the engine bay in one hit Has a slight oil leak as when gearbox was put onto efi engine I had drive shaft seals replaced think its leaking from there Also Very Very Rarely when you pull up at lights it will cut out if you drove 100 miles it would probably do it once im just trying to tell any bad point no matter how little they seem to be! will restart instantly I think iv covered everything if you are after a truly stuuning example of a great classic then look no further very little is needed to finish the car viewing is welcome Has number plate G5 TOO which has been valued at £950 if you want to keep it will be an extra £500 if not the standard plates will go back on
Any questions just ask away
Old Sep 10, 2013 | 02:18 PM
beemer1664's Avatar
beemer1664
Default price
£2750 with out plate, £3250 with
Old Sep 10, 2013 | 02:50 PM
J600ohn's Avatar
J600ohn
Very nice. Looks perfect! Would benefit from a white bonnet but still very sexy
Old Sep 10, 2013 | 05:08 PM
RS-Rikki's Avatar
RS-Rikki
Would be very interested in this when my insurance money comes through
Old Sep 11, 2013 | 01:59 PM
beemer1664's Avatar
beemer1664
If its still available your more then welcome to view mate
Old Sep 15, 2013 | 12:50 PM
beemer1664's Avatar
beemer1664
Price drop £2500 without plate £3000 with
Old Sep 18, 2013 | 07:24 PM
beemer1664's Avatar
beemer1664
Still available
Old Sep 18, 2013 | 08:25 PM
Stunning car.It looks mint on the escos wheels.
Old Sep 19, 2013 | 08:48 PM
RS-Rikki's Avatar
RS-Rikki
Pm d u twice mate
Old Sep 23, 2013 | 11:55 AM
RS-Rikki's Avatar
RS-Rikki
Anyone know if this car is sold or for sale very interested but can't get hold of him
Old Sep 23, 2013 | 11:56 AM
RS-Rikki's Avatar
RS-Rikki
Is this still for sale very interested but can't make contact
Old Sep 23, 2013 | 01:05 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
Anybody know where I could get that modded air vent from so a stereo could be fitted higher up the dash?
Old Sep 23, 2013 | 03:13 PM
Smit's Avatar
Smit
The 60ft Launch King
RS-Rikki - Last Activity: 18-09-2013 09:25 PM
He's not been ignoring ya, just hasn't logged on
Old Sep 23, 2013 | 03:34 PM
RS-Rikki's Avatar
RS-Rikki
Can be frustrating lol
Old Sep 23, 2013 | 08:13 PM
Gadget's Avatar
Gadget
Spanner monkey
TWINS
Old Oct 11, 2013 | 07:06 PM
beemer1664's Avatar
beemer1664
Sold to rikki, enjoy it mate will be sadly missed
bigryrs
Sep 7, 2015 06:45 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
