Conrod bearings
Old Sep 7, 2013 | 05:16 PM
turbobill's Avatar
turbobill
Default Conrod bearings
Got low compression on cylinder 4, got low oil pressure when engine is warm, just took conrod cap of, what do you think, nackered?? Or they okay?
Cheers bill
Old Sep 7, 2013 | 06:03 PM
Ben26's Avatar
Ben26
I would say a bit warn, I personally would replace after finding out the cause
whats the crank like, who measured them up >?>
how many miles had they done ??
Old Sep 7, 2013 | 06:12 PM
turbobill's Avatar
turbobill
Not got a clue, bought it of here a month ish ago, ment to have been rebuilt, about 500 miles ago? But this is my first experience with doing a bottom end so need a little help lol, didnt think they looked right tho from what i read on here
Old Sep 7, 2013 | 06:15 PM
Ben26's Avatar
Ben26
when u say one piston was low in compression by how much ??
cant u just ask the guy u bought it off what the deal was with it ?
Old Sep 7, 2013 | 06:19 PM
Ben26's Avatar
Ben26
I would say this deepish scoring needs to be looked at
I wouldn't re use them now. but then u mite have to get the crank re ground
Old Sep 7, 2013 | 06:25 PM
turbobill's Avatar
turbobill
First three was 8 bar 4th one was 5 bar
Old Sep 7, 2013 | 06:26 PM
turbobill's Avatar
turbobill
And hes not answering me
Ben26's Avatar
Ben26
3 words for you my friend are needed;
STRIP
IT
DOWN
Ben26's Avatar
Ben26
just check everything over and measure shit up then u know where u stand
Old Sep 7, 2013 | 07:23 PM
botters's Avatar
botters
competant bodger
yep they look worn to me, the sacrificial white metal is gone and there are a few scores too
Old Sep 7, 2013 | 08:53 PM
turbobill's Avatar
turbobill
Okdokie thanks for your help everyone, looks like rebuild time lol cheers bill
Old Sep 7, 2013 | 09:22 PM
luke19790_3's Avatar
luke19790_3
Hope you didn't pay too much for the car rebuild time
Old Sep 7, 2013 | 09:29 PM
turbobill's Avatar
turbobill
Had the car a while now, bought engine, turbo and gearbox, of here about montj or two ago, with the engine supoposingly been rebuilt about 500-1000 miles ago, but hes since blocked my number so i carnt get hold of him,
So rebuild time it is
Cheers bill
Old Sep 7, 2013 | 09:34 PM
luke19790_3
Stick a st170/blacktop lump in
Old Sep 7, 2013 | 09:39 PM
turbobill's Avatar
turbobill
I been looking into doing a zvh, rung simon up at sitech racing and he said use a 2.0 blacktop block, hes got a special headgasket what blanks the extra oil galleries of, got to enalrge the water pump hole for cvh waterpump, block te breather on front and put one on the back and put a oil return in, so that sounds pretty sinple, so half tempted to go down that route,
Old Sep 7, 2013 | 09:42 PM
luke19790_3
St170 engine, sell the head after nicking the springs. Fit a std blacktop head with the st170 springs and a thicker focus rs gasket.
Old Sep 7, 2013 | 09:44 PM
turbobill's Avatar
turbobill
That sounds good, but not got alot of money atm, plus i still want a turbo, and im gonna then need management to
Old Sep 7, 2013 | 09:45 PM
luke19790_3
Zvh will cost the same
Old Sep 7, 2013 | 09:58 PM
turbobill's Avatar
turbobill
Not if i only need a block surely? Cos i can do the work
Myself, but id need to buy the management ? Im new to these conversions so correct me if im wrong,
Old Sep 7, 2013 | 10:49 PM
botters's Avatar
botters
competant bodger
to be honest a zvh these days is a waste of time for what it costs you may as well go zetec turbo, get a 2.0 zetec use a focus rs manifold (inlet and exhaust)and turbo (plenty for sale due to upgrades) good strong 200 plus engine for less than a worked unreliable cvh
Old Sep 8, 2013 | 09:00 AM
turbobill's Avatar
turbobill
How much would that cost then? With including new management etc?
Old Sep 8, 2013 | 09:33 AM
Ben26's Avatar
Ben26
, hes got a special headgasket what blanks the extra oil galleries off
So no more welding the boock then ? Sounds strange . I thought it was the water way that had to b blanked off anyway ?
Old Sep 8, 2013 | 09:48 AM
turbobill's Avatar
turbobill
Im not sure, he just said hes got the special gasket what saves blocking the extras of, thats all i know mate,
Old Sep 8, 2013 | 10:57 AM
turbobill's Avatar
turbobill
Bit of an update
Took the rest of the conrod caps of today, to check the other bearings, they all the same, with a few score marks, checked the crank and i think i maybe lucky, theres a few marks, but carnt feel them, il post a few pictures up ina bit, i guess with the conrod bearings gone like tht, thats the reason to why i get low oil pressure when its warm?
Cheers bill
Old Sep 8, 2013 | 12:40 PM
Ben26's Avatar
Ben26
told ya mate , worth a strip down defo
Old Sep 8, 2013 | 12:50 PM
turbobill's Avatar
turbobill
So would you take the main bearings out to? If i take them off and there okay, can i reuse the bearings n bolts or do they need replacing?? Cheers bill
Old Sep 8, 2013 | 01:08 PM
Ben26's Avatar
Ben26
If the main bearings are fine yea re-use them defo and yea re-use the main cap bolts But if your rods had ARP bolts in then get a new ones, but if they are the standard bots then re-use them if that's what u ment
Old Sep 8, 2013 | 01:24 PM
turbobill's Avatar
turbobill
Oh okay sweet, il take them out ina bit then and have a little look, didnt really take notice to wether the conrod caps had arp bolts or standard. But i thought you could reuse arp ones and not standard ones??
Old Sep 8, 2013 | 02:00 PM
Ben26's Avatar
Ben26
ARP nut n stud headbolts u can re use but I wouldn't risk it if u r using ARP ronrod bolts, but others may disagree
Old Sep 8, 2013 | 02:04 PM
turbobill's Avatar
turbobill
Okay then mate, so just to clarify things, if my main bearings are okay i can reuse those. But buy new bolts, and obviously new conrod bolts and bearings
Old Sep 8, 2013 | 02:11 PM
Ben26's Avatar
Ben26
Main cap bolts ======== =========RE-USE
Conrod bolts ==================RE-USE ( only if they are standard )
Main bearings/shells if in nickgood ==== RE-USE
Check for play in the crank in and out as u mite need thrust bearings as well. Crank mite need to get re ground for over size thrust bearings ( they sit in the middle of the crank and are thin half moon shapped pieces of metal lol
Old Sep 8, 2013 | 03:35 PM
turbobill's Avatar
turbobill
Okay thankyou for that, sorry it took a while for me to understand lol,
Gave the crank a good tug, pushed it in and out and wasnt any movement, so think im okay there, just bought a engine stand, so il get that n then check my main bearings,
Thankyou for your help
Bill
Old Sep 8, 2013 | 03:40 PM
Ben26's Avatar
Ben26
Bill
no probs.
an engine stand is a must for anyone who is messin round with engines, its hard working off the floor or bench, especially when u need to keep flippin the engine round
Machine mart do a good engine stand, cheap as well:
http://www.machinemart.co.uk/shop/pr...C-engine+stand
this is the I got and is spot on.
Old Sep 8, 2013 | 03:45 PM
turbobill's Avatar
turbobill
I found one on ebay, close to me, man bought it but never used it, so its brand new practically, so gunna be going to collecting that in a while hopefully, thanks for the linky though
Old Sep 8, 2013 | 04:03 PM
luke19790_3
Depends how much you can do.
How much will the zvh cost?
Old Sep 8, 2013 | 07:58 PM
turbobill's Avatar
turbobill
Not to much, need to buy the block, headgasket, and tensioner, n a few fittings..
Old Sep 8, 2013 | 08:08 PM
turbobill's Avatar
turbobill
Okay so took my main bearings of tonight, to see the condition of them, only tool the caps of. Most of the white is still on, theres a few marks but carnt feel any, apart on one which i can feel ever so slightly, crank is okay, no scores, would you recomend replacing them or reusing them? Heres a few pictures ..
Thanks for looking, bill
Old Sep 8, 2013 | 08:28 PM
luke19790_3
There is one sale on ebay for 245, sale the head and use that money o buy a blacktop head.
The sitec gasket is 115
Old Sep 8, 2013 | 08:30 PM
luke19790_3
Looks like it was caused by dirt when the engine was built. I'd strip it down check the crank and replace the bearings.
But didn't you also have issues with low compression?
Old Sep 8, 2013 | 08:36 PM
turbobill's Avatar
turbobill
That sounds okay, sounds good, how much is management etc then?
Regarding the shells, i did wonder that myself, crank seems okay so hoping i can just replace the shells, i did have problems with low compressionon one of the cylinders, but believe thats the head, as the valve jacket had lots of pit marks and was rough on the edge, so think it was leaking through, checked the bore lining and all seem okay no score marks or cracks, cheers bill
