Burton 4x4 cosworth oil pump
Old Sep 7, 2013 | 08:55 AM
COLEYST200's Avatar
COLEYST200
Default Burton 4x4 cosworth oil pump
Hi lads in thinking of getting a burton 4x4 hi pressher oil pump as I'v got to do some work on my focos motor . Dose any one no if there any good or has there been any problems with there pumps
Old Sep 7, 2013 | 09:10 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Get one from here mate
http://www.protechmotorsport.com/cosworthyb.htm
Old Sep 7, 2013 | 09:23 AM
COLEYST200's Avatar
COLEYST200
I might do that mate its just I'v been offerd a hi pressher burton pump brand new Ł125 and that pump is Ł140 + vat :-(. for a oil pump when I can get a good hi pressher pump for a 2wd Cosworth for Ł30 it's just a rip of these 4x4 pumps I'v been told that you can get the 2wd pump to fit with a bit of modding I might look at that in a bit . Thanks for your help mate
Old Sep 7, 2013 | 06:35 PM
Wasnt there a few burton oil pumps that failed and caused damaged to engines
Old Sep 7, 2013 | 07:20 PM
botters's Avatar
botters
competant bodger
ive always been told there is no need to fit a high pressure pump and that a good quality standard pump is fine
Old Sep 7, 2013 | 07:40 PM
tones's Avatar
tones
Default Burton oil pump
I got one earlier in the year and had to send it back as it was not the best it looked cheep and the dowel on the bottom end would not line up to the pump so sent it back had to wait for my money back and did not give me my postage back...... So I got one from Matt Lewis and was spot on and was not much more as well
Old Sep 7, 2013 | 07:53 PM
LHD220Turbo's Avatar
LHD220Turbo
no need for HP pump, standard one is fine
i recall Tony at Turbo Systems saying only to use a standard pump aswell
Old Sep 7, 2013 | 08:31 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
For a genuine cosworth pump, try ds motorsport on ebay.
Old Sep 7, 2013 | 10:03 PM
wattie's Avatar
wattie
My engine was built with a second hand oil pump and its been fine for 5k miles so far! There's been a few horror stories about the burton ones so I would steer clean just in case
Old Sep 7, 2013 | 11:06 PM
dingla rs's Avatar
dingla rs
Just buy one off Matt Lewis Ian were mine came from
big_Rad
Sep 15, 2017 09:36 AM
Dubs44
Aug 21, 2015 02:42 PM
mrmann
Aug 20, 2015 11:24 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
