mondeo mk3 central locking problem
Old Sep 4, 2013 | 07:04 AM
azzkill's Avatar
azzkill
Default mondeo mk3 central locking problem
Hello. I have a problem with the central locking on a mondeo mk3. None of the doors respond to the remote. And when using the key only the driver side door opens. All doors need to be opened manually. And the boot also needs the key to open. The button inside the car does not open the boot either. Could this be the central locking module that needs to be changed? Is it something I can get from a scrapped mondeo and change myself or do I need a new one and get it programmed by ford? Thanks for all help.
Old Sep 4, 2013 | 01:56 PM
azzkill's Avatar
azzkill
Nothing more than a blown fuse so now the central locking works 95%. Only need to fix the sensor in the boot. Shows it is open all the time.
Rob Wells
Apr 18, 2023 12:19 AM
Chopshop85
Sep 12, 2015 06:42 PM
imnoteasy
Sep 7, 2015 09:26 PM
cossirob
Sep 3, 2015 09:17 PM
Bighandsuk
Sep 2, 2015 05:23 PM
