Trader Parts for Sale. Only Registered PassionFord Traders can sell parts in here. Buy with confidence.
YB Cosworth Tool Tray (New Product now In Stock)
Old Sep 3, 2013 | 11:34 AM
Stu @ M Developments's Avatar
PassionFords Creator
Default YB Cosworth Tool Tray (New Product now In Stock)
Awesome new product for all you Cosworth YB owners.
No more leaving tools on the scuttle panel, slam panel or windscreen wipers after working on your car. No more dropping tools down into the engine bay or loosing nuts and bolts after balancing them on the engine somewhere. The ultimate YB Tool tray is here!
These tool trays are a direct and secure fit to suit all Ford Cosworth YB engines.
Made from 1mm mild steel and powder coated satin black with punched and flared holes for that Motorsport look, big turbo and small turbo versions are both available and can be used with strut braces and turbo dampers left in place as well as all known HT Leads.
The legs locate securely in the cam cover bolt hole recesses eliminating the risk of the tray slipping off or moving at all during use.
Each tray has plastic feet to protect your cam cover's paint from scratches during use and also comes with a non slip tool tray liner for the inside.
This is an Invaluable piece of kit when working on your pride and joy and greatly aids the speed with which you can take her apart as you have somewhere to safely and securely place all nuts/bolts/spanners etc instead of balancing them all over the place.
**Please Note**
The tool tray locates in the 2 front and 2 rear cam cover bolt hole recesses - so these need to be clear! We cannot account for where people run breather hoses or wiring loom earths so please be aware of this before ordering.
The tray sits 123mm above the lowest point of cam cover and this clears all known strut braces we have come across so far but please email if this needs to be higher for your car as we can have one manufactured especially for you.
See more at: http://shop.motorsport-developments.....Qi9lFyf2.dpuf
In stock now for next day delivery.
http://shop.motorsport-developments....ays-1533-p.asp
Old Sep 3, 2013 | 11:55 AM
fraser9764's Avatar
fraser9764
Are the 4 corner bolts in the same position on a small turbo cam cover?
Old Sep 3, 2013 | 11:59 AM
Hi mate, the ST cover is slightly different, there is a dedicated one for that, choose choose the one you want in the pulldown menu on the shop.
JK12
33
Apr 26, 2021 12:09 PM
oilman
Aug 30, 2015 08:37 AM
gjh
Aug 24, 2015 04:38 PM
Aug 14, 2015 07:29 AM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
