Could I be losing power because of this......
Notice the 2 Dump Valves.....only the one on the hose is connected but could I be losing power by the other one just being there?
I have just put a post up for a swap for a standard crossover pipe with mine and as soon as I can I will get a new hose with no hole for a dump valve!
Tiff.....As soon as karl has done his magic and told me what needs doing I will get it all done and spend a day with some of this shit my mum got off QVC! You know the stuff that makes 2p's look like new?
Originally Posted by Porkie
Originally Posted by TIFF-C20WTH
Plug them both off mate
And clean that fookin engine bay you tramp
Before I take it to Karl I will be giving it a good old service (Plugs, Leags, Rotor Arm and Cap, fuel and oil filters)
Will give the engine a good old jet wash to get all the shite off at the same time also
Im not on abou the dirtyness though, just wanna know if that gay chavvy blue fookin dump valve is making my car slow and gash before I burn it!
"Just Jet-washed my engine , now it wont start-HELP"
As said above, junk both DV's they're not required on an RST, and mainly cause trouble (air leaks), imo.
So in answer to your question: YES! lol
But boggin plug leads can cause ignition problems too, so wasn't mentioning those for cosmetic reasons
So if I fook both of those sneeze machines off it should run better? In simple terms?
Is that simple enough for you
Thanks
"Goes to find a hacksaw to take them off"
Just to check why don't you remove the one on the hose, and temporarily blank it with a 1" bit of broom handle - then put the vacuum pipe on the charge carrier one!! see if you get the power back!!
dont need a new pipe ...
get a broom handle and chop a bit off.. jubilee clip and your done
much cheaper
see 2 of us recomend it .. nothing to beat a broom handle
or spend 10 quid odd for a shiny bit of ally that does the same ...
much cheaper
i would put it back to standand with all new samco hoses, silcon spray all conection's electrick's then truck wash or ciltit bang(not porn)spray then steam clean then rolling road emissions tune up full heath,Check cambelt history and put cover back!!!!!
The new crossover pipe minus gay sneeze valve should be here tommorow!
That wil be going on ASAP and I am giving it a full service at the weekend which is when I will clean the engine bay up
Thanks for your help guys!
Originally Posted by pauldudley
ciltit bang does it work?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
deathrider666
Sep 28, 2015 06:12 PM
