flat face 5 spoke compomotives
Old Aug 26, 2013 | 05:38 PM
RONNIE AMIS's Avatar
RONNIE AMIS
Default flat face 5 spoke compomotives
selling my flat faced 5 spoke compomotives
they are 8 x 17 et 15 group a fitment. painted orange beginning of this year and then never used, all straight
£600, these are hard to come by now days
thanks
Old Aug 27, 2013 | 08:44 PM
IainRS1700T's Avatar
IainRS1700T
Hi Ronnie
What's the largest brakes I could squeeze inside these?
Would I get away with 356mm AP's?
Iain
Old Aug 27, 2013 | 08:46 PM
RONNIE AMIS
I'm not 100% sure Ian. I reckon they might just squeeze in
Old Aug 27, 2013 | 08:48 PM
IainRS1700T
Hmm it's going to be tight I know.
I'd like to know for sure before spending my hard earned though.
I'll do some more homework.
Thanks for your quick reply.
Iain
Old Aug 27, 2013 | 08:56 PM
RONNIE AMIS
Ok mate you're welcome to try one for size but know you're not local are you
Old Aug 27, 2013 | 09:06 PM
johnyjn's Avatar
johnyjn
I've got 355 discs with ap cp5555 6 pot calipers on my 3dr with these wheels but with a et 35 off set
Old Aug 27, 2013 | 09:10 PM
IainRS1700T
No 'fraid not local to you Ronnie!
Johny many thanks for your reply, that's exactly the set up I have on my 3dr with Comp Mo 6 spokes, but 18".
My ET is 33 plus a v slim spacer, so pretty much on 35, so Ronnie, although I've cracked the clearance issue, the ET isn't going to work for me sorry.
Thanks for your help gents.
Iain
Old Aug 27, 2013 | 09:35 PM
Sonic Boom's Avatar
Sonic Boom
I've got AP7040 6 pots and 355mm discs behind mine they cleared with an ET33 although i'm now out to ET17 with spacers (just to widen the track)
Iain i'm sure you could have them machined down to the right offset for you.
Rich
Old Aug 27, 2013 | 09:42 PM
IainRS1700T
Rich
Thanks for your reply Rich.
I'm not sure I follow though. If you've added spacers your ET should now be larger shouldn't it?
ET 33 is the inner face of the wheel centre, 33mm away from the centre line of the wheel. To be ET17 would mean that you've reduced that distance, not increased it as you say. Zero being the centre line..
OR.. have I got this offset business completely wrong?
With Ronnie's being ET15 the mounting face of the wheel is only 15mm off the centre line of it's total width. To get to ET35 for example, I would need a 20mm spacer?
Happy to stand corrected, but that's my understanding..
Iain
Ah, just re-reading your post - you're saying your wheels are ET17 AND you have spacers on.. with you now.. That clears that one up. I really don't want to run spacers though. Cheers
Old Aug 27, 2013 | 09:55 PM
RONNIE AMIS
You definitely wouldn't need to run spacers. Can't explain exactly et
But the lower the et the further the wheel sits out.
So et15 will sit 15mm further out than a et30
Old Aug 27, 2013 | 09:59 PM
IainRS1700T
Thanks Ronnie, I'm getting there with that stuff now - it was the spacer bit of Rich's post which foxed me before!
I've got huge arch mods, but I can't see getting away with pushing the outer edge of the wheel any further than I am now, even if I am going down to 17's.
Thanks again, GLWTS
Iain
Old Aug 27, 2013 | 10:11 PM
Sonic Boom's Avatar
Sonic Boom
Sorry I didn't need to add the bit about the spacers really lol
The lower the ET or offset means the further they stick out (giving better brake clearance) Althought you don't need ET15 or ET17 to clear AP 6 pots only ET33.
So you'll beable to machine the current ET15 down to ET33 if you like to get them to fit under the arches but still clear your brakes.
Iain is it a 3 Door you have?
Rich
Old Aug 27, 2013 | 10:17 PM
IainRS1700T
Yes mate it is.
Do you think there's that much meat on the wheel centres to whip that much off?
It's possible.. Compo have two sizes listed ET15 to 35 and 35 to 50 so maybe they came off the same moulding.
Only thing is now the cost is rising.. machining and paint (sorry Ronnie, orange isn't my thing LOL)
Iain
Old Aug 28, 2013 | 01:11 PM
JayCC's Avatar
JayCC
You can't machine et15 to et30 without adding material..?
Old Aug 28, 2013 | 01:41 PM
AJC's Avatar
AJC
You can go from 15 to 30 yes as the 15mm is of centre of the rim. Remove another 15 and you get ET30
Nov 1, 2015 06:53 PM
chowfornow
Alloy wheels and ICE for sale
15
Oct 17, 2015 07:09 PM
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
