sender for s2 fuel tank?
Old Mar 19, 2005 | 08:12 PM
ballin's Avatar
ballin
Default sender for s2 fuel tank?
heres the story....
current fuel tank on my s2 started leaking so i ordered a new one from someone on here - just said it was a ersts2 so expected the right one as he obviously knows his fords!
anyway, took it all apart today old tank out etc. and goes to put the new one in and the sender hole is roughly double the size of the original tanks hole
basically this is the tank I have:
and this is the tank I was sent:
it all fits bar the sender (albeit the vent is at the wrong angle but thats no biggy.
so anyway, i pm'd matey and he basically said that my old tank must be wrong (?) as all series 2s have a large sender....
is this correct?
He went on to say the small sender doesnt have a swirl pot, however i checked and it does...
so basically i have a small sender and a swirl pot; which apparantly isnt possible
who's right, and more importantly what should I do cos i need the thing moving cos its taking up someones garage atm....try and find a tank with a small sender and swirl pot or buy a large sender?
anyone had one out that can confirm whether im right/wrong?
ps. it is the original ford tank so i think im right
cheers
Old Mar 19, 2005 | 08:36 PM
nigel b's Avatar
nigel b
im sure the s2 sender has a big hole
mk3 tanks have the sender on the side so it isnt that
Old Mar 19, 2005 | 08:41 PM
adamS2RST's Avatar
adamS2RST
Rich ur right, them tanks are the SEL tanks arn't they. fcuk didnt think u would have this prob, check one of my old threads before I was gunna ordrer one of these (I rang them and they couldnt confirm they had swirl pot and small sender which mine is exactly like urs)
Thread here: https://passionford.com/forum/viewto...ight=fuel+tank
I used my old tank in the end and painted it up cos I knew I would have probs ordering one of those!
Old Mar 19, 2005 | 09:30 PM
ballin's Avatar
ballin
yeah ive had a good read through that adam, fookin confused just like you!
im glad yours is the same as mine confirms even more im right (not ordered from SEL btw but prob. was sourced from there)
cheers for that nigel, i duno tbh seems s2's are supposed to have a large sender but none of them actually do
Old Mar 19, 2005 | 09:37 PM
adamS2RST's Avatar
adamS2RST
Rich, Tricky seemed to know his stuff:
on Efi models the pump/sender was 1 unit, when they say in the tank its just screwed in by 60 degrees, thats your fuel pump/ sender.
earlier mfi cars had the external bosch pumps under spare wheel well, if ordering for RS Turbo you want the early type tank from 86 on (also does the mfi XR3i), if an Efi XR3i then the 89 on tank with large sender hole.
hth
Tricky
if you have an RS Turbo Mk4 order the 86-89 tank(small sender) even if your car is 1990-all RS Turbos (as far as i know anyway had pump under spare wheel well).
word of warning though-if ordering from sel before signing for delivery check it has swirl pot inside, we have a trade account with them and order quite a few tanks, quite a few of the pattern tanks havent got swirl pot.
hth
Tricky
I got confused by their pics tho (the ones u have posted above) the holes are wrong as u say....I'd be tempted to buy an original ford one, I got a quote for one from fordpartsuk it was arounf £140 tho iirc
Old Mar 19, 2005 | 09:40 PM
Lee Reynolds's Avatar
Lee Reynolds
mines got large sender
Old Mar 19, 2005 | 09:41 PM
ballin's Avatar
ballin
He's the guy i ordered from
not blaming him really, he's obviously going by a book listing or whatever but its down to me to prove its wrong i think
Old Mar 19, 2005 | 09:42 PM
ballin's Avatar
ballin
cheers Lee, fook knows whats going on then....what year is yours maybe it really is an 89-90 thing as on SEL?
might have to try them adam ta...or maybe A.R.E etc might have more luck
Old Mar 19, 2005 | 09:43 PM
Lee Reynolds
89 G plate mate. IIRC my old 89 was same big sender
Old Mar 19, 2005 | 10:02 PM
ballin's Avatar
ballin
ah pish, there goes my theory then
any ford people able to confirm on the parts computer?
Old Mar 19, 2005 | 10:25 PM
KSA-Cossie's Avatar
KSA-Cossie
Early s2's had small hole sender.
Old Mar 19, 2005 | 10:38 PM
adamS2RST's Avatar
adamS2RST
mines an 89 G.
Rich, I could try get finis code if u want
Old Mar 20, 2005 | 05:49 AM
edd's Avatar
edd
your right rich, he sent the wrong tank, tell him your car has the original tank and hes a knob.
Old Mar 20, 2005 | 05:59 AM
starturbo's Avatar
starturbo
Mine has a large hole for the sender (89 F reg)and I got a replacement from ford and that had a large hole as well.
Old Mar 20, 2005 | 06:02 AM
edd's Avatar
edd
rich there will be part number on the tank take it to ford and find out what tank you need.
Old Mar 20, 2005 | 08:35 AM
ballin's Avatar
ballin
cheers all obviously 2 different ones in existance for no apparant reason
ill see if i can get a number off the old tank altho its pretty manky....didnt wanna get one from ford if i could help it tho ; pretty expensive!
Old Mar 20, 2005 | 08:40 AM
starturbo's Avatar
starturbo
got mine trade mate.I found an XR3i tank in the scrapyard but my mate said it would work fine until the car was really hot in the middle of summer and then i would have problems with the engine hunting because of the size of the swirl pot in the tank.The rs tanks swirl pot is bigger apparently?How do they get the pot in the tank?Might be before they weld it shut but surely not through that little hole?
Old Mar 20, 2005 | 08:44 AM
ballin's Avatar
ballin
before its sealed i would imagine.
can get staff discount from ford but thats it...might make it a bit more bearable will go on monday and at least find out why some cars had small and some large i suppose!
Old Mar 20, 2005 | 09:06 AM
adamS2RST's Avatar
adamS2RST
What? they will know that? You have good parts people! ours don't know shite!
If I can get on my other puter l8tr i'll try and find the numbers.
Old Mar 20, 2005 | 09:57 AM
ballin's Avatar
ballin
yeah f'boro ford are spot on actually, or one matey there is anyway
if you can that would be wikid mate
Old Mar 20, 2005 | 02:39 PM
adamS2RST's Avatar
adamS2RST
Rich,
I got two p/n for you.
firstly I think you will need: 6172223 08/89 - 08/90
also, I was quoted this from fordparts:
Escort RS Turbo- Fuel Tank
Part Number: 6172223
Retail Price: £135.17
You Pay: £114.89
Delivery
UPS £9.99
Prices subject to VAT @ 17.5%
Total Cost: £146.73
There is another tank listed also. early one, incase u want it: 1640749 01/86 - 05/89
HTH mate.
Adam.
timsrs
Nov 13, 2018 11:48 AM
mpilk
Sep 27, 2015 09:21 AM
