problems with engine swap escort rs2000
Old Aug 19, 2013 | 05:45 PM
nicolas rs's Avatar
nicolas rs
Default problems with engine swap escort rs2000
hey i from Belgium ,
and this summer my escort converted from engine; 1.8 16v to rs 2000, 96 '
was a lot of work ...
the donor car
and my car
after the work ....
Now let the motor do not run, the starter motor works, gets petrol, but get no ignition,
Now let the engine do not run, the starter works, gets petrol, but get no ignition,
outside the block is complete the wiring harness of the donor outside the doors and trunk
Vertalen van: Nederlands
Vertalen naar: Engels
Vertalen In samenwerking met Hmong-taalpartners
In samenwerking met Tilde
In samenwerking met JNU
In samenwerking met CBS, Paramount en KLI
buiten het blok is de kabelboom van de donor kompleet buiten de deuren en koffer ,
buiten het blok is de kabelboom van de donor kompleet buiten de deuren en koffer , outside the block is complete the wiring harness of the donor outside the doors and trunk,
Old Aug 19, 2013 | 05:54 PM
nicolas rs's Avatar
nicolas rs
This I come across, 1 is for the roof window but this different I don't know
problem is the computer says, connect to, but this is on! , and when we create the right headlight begtint burn and the window in left door does not work
Please help ..... I want ride with that thing
Old Aug 19, 2013 | 05:56 PM
nicolas rs's Avatar
nicolas rs
JoeyBoyden
Jan 4, 2024 02:36 PM
Vincereese
Jun 1, 2023 09:14 AM
druidgetafix
Aug 15, 2015 10:22 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
vdubo7
Aug 2, 2015 08:17 PM
