Show me your 17's, fiesta rs turbos
Show me what 17's your running on frst's
May need to go to some because my brake upgrade is larger than I thought, I'm going to try with 16 but I'm not feeling very lucky tbh
Start with the braking and handling first then full zetec turbo is my plan, was more of the fact they were there as I was looking and though it was a brilliant idea, just a little concerned about needing 17's now, don't like the idea of running on 17's, as above it'll handle like a dog
id try compomotives in a 16 ,they might fit.. as for 17's i ran them years ago with no major issues but a fair bit of rubbing...look at the new ff mag,rob's fiesta on the cover has 17's as he has massive brakes
..i now run 300mm disc's with AP racing 4 pots under 15 inch comps so you might get away with 16's
mine;
mine;
Yeah the one on the cover, oz superleggas I believe? They don't look too out of place IMO, and yours doesn't look silly frsjon, better than I thought 17's would look anyway,
Here's the brakes
And the comps
I sort of test fitted them and there was one bit of the caliper that was catching, so I've ordered a set of brackets to fit them properly and see what the score is, maybe a bit of caliper filing on the notch at the top might sort it
Here's the brakes
And the comps
paceo
Feb 3, 2016 10:31 AM
Matt Baxter
Sep 16, 2015 08:30 PM
