don't run good
hello , i have a problem with my engine cvh1600 .
the specs are :
- cvh1600 xr3i stock bottom end
- hemi head , ported
- rs1600i valves
- rs1600i springs
- newmancams mechanical followers
- rs1600i camshaf
- rs1600i exhaust manifold
- twin weber 40 , 36 choke , correctly jetted
the engin can't run under 6000 rpm and i don't know why ?
at the past i changed ignition , fuel pump , cam belts , plugs , etc etc all had change 3 times , but the engine continue to cut at 6000 rpm
help me , i don't know what is my problem
on this video you can listen the engine cut at 6000 rpm
the specs are :
- rs1600i valves
- rs1600i springs
- rs1600i camshaf
i use xr3i distributor bosch .
i tryed : xr2 lucas distributor , escort lucas distributor and another bosch xr3i distributor .
no differences between these .
i tryed another plugs ( denso , qc57c , motorcraft .. )
another ignition leads
another ignition coil
and electrical connections
no differences
no differences
If it is not ignition related issue I would guess at valve spring float.
Weak valve springs can certainly be a rev limiter.
Were the rs1600i springs new? What was the installed valve spring height?
rebuilt heads typically sink the valves which requires shimming to bring the valve spring closed height (installed height) to the correct spec.
