Suggest me a digital dash
Old Aug 18, 2013 | 08:10 AM
Billy_RS's Avatar
Billy_RS
Default Suggest me a digital dash
Looking for a digi dash, looked at stack, aim and pi systems.
Looking for people with experience of using a digi dash input really.
Cheers billy
Old Aug 18, 2013 | 08:12 AM
Cossy Mike's Avatar
Cossy Mike
With pics as well
What's Ronnis Amis running in his, never seen anything like it before?
Old Aug 18, 2013 | 08:33 AM
whizzisat114's Avatar
whizzisat114
Ive just fitted a dash2 into dinglars's focus cosworth .seems a very informative dash with 5 different screens to view .loads of features
www.race-technology.com
Old Aug 18, 2013 | 08:35 AM
gus's Avatar
gus
thats what i just got for mine
Old Aug 18, 2013 | 08:42 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Anyone know if any of these dash's will plug into an autronic sm4 ecu
Old Aug 18, 2013 | 09:39 AM
Billy_RS's Avatar
Billy_RS
Sounds a good bit of kit, for half the price of a stack dash.
How did you find it fitting it?
Old Aug 18, 2013 | 09:41 AM
Billy_RS's Avatar
Billy_RS
Looking at their website it seems they fit every aftermarket ecu except autronic
Old Aug 18, 2013 | 09:57 AM
polly_x's Avatar
polly_x
The AIM will work with the Autronic.
Personally I think the AIM is the superior digi dash. The Dash2 oftens wins on price though for most people. The AIM's configuration software is light years ahead. I configured a Dash 2 for someone a few weeks ago and it was not a nice experience!!!!
There is a new version of the MXL out soon too which although I have not used looks even better. It's WiFI for configuration too by the looks of it.
Stu
Old Aug 18, 2013 | 10:37 AM
Beetlejuice's Avatar
Beetlejuice
What's the budget?
Old Aug 18, 2013 | 10:53 AM
Billy_RS's Avatar
Billy_RS
Originally Posted by Beetlejuice
What's the budget?
Haven't really got one tbh
Old Aug 18, 2013 | 10:57 AM
Beetlejuice
http://www.gems.co.uk/?content=pages...colour-display
Old Aug 18, 2013 | 11:10 AM
Billy_RS's Avatar
Billy_RS
Looks a bit to me.....
How much they worth? Can't find a price
Old Aug 18, 2013 | 12:04 PM
Beetlejuice
A lot. Around £1700 for the 4" display. The larger ones are up to around £4k last time I saw, but I think there's been w price increase recently.
Looks right at home in the BAC Mono:
Or in the MP4 GT cars:
Old Aug 18, 2013 | 12:13 PM
JonnyBravo's Avatar
JonnyBravo
The Race Technology dash is undoubtedly very good value for money, however as a company they are hard work to deal with and the software as Stu has mentioned is not very nice to work with.
Once you have your head round how to calibrate stuff its not all that bad but that can take a while.
Old Aug 18, 2013 | 12:25 PM
Will Pedley Racing's Avatar
Will Pedley Racing
willpedleyracing.co.uk
I've just recently attained UK Distributor status for AIM products.
If you just want to display chosen data from the Autronic ECU, then a MXL Strada unit will do that for you. You also have the option of adding an additional 8 0-5v analogue channels for any sensors that don't run through the ECU.
If you want to datalog information to analyse later on, then the MXL Pista unit is the better unit for you. Using the supplied software, you can build up a very good picture of what is going on.
For example, this screenshot shows throttle position plotted against a track map build from the internal lateral and longitudinal G sensors:
Price wise, I can supply you with a MXL Strada for £795.00 + delivery or a Pista for £1495.00 + delivery.
More than happy to answer any questions on these units if you have any
Old Aug 18, 2013 | 12:35 PM
Billy_RS's Avatar
Billy_RS
I don't really want it to be too fancy. Just really want speed, rpm, oil pres, oil temp, water temp and maybe boost all in one unit.
Data logging, action replay etc not interested in.
Old Aug 18, 2013 | 12:59 PM
Will Pedley Racing
It sounds like the MXL Strada will be more than adequate for your needs. Do you already have the Autronic ECU and loom? If so, do you know if it has the provision for oil temp and pressure?
If not, I can supply you a sensor that will measure both oil pressure up to 10 bar and oil temp up to 150 degrees C. The sensor outputs can be connected directly to the AIM dash or into the Autronic if there are spare 0-5v inputs.
Old Aug 18, 2013 | 01:03 PM
Billy_RS's Avatar
Billy_RS
No I'm on L8 at the moment, I think James asked about autronic.
Is L8 not going to be able to support a digi dash then?
I just thought it would wire up to the original sensors etc? Or am I way off?!
Old Aug 18, 2013 | 01:12 PM
Will Pedley Racing
Ah, my apologies!
I misread the earlier posts
No, L8 won't support a digital dash. The sensors cannot be piggybacked reliably to supply both the ECU and a digital dash. It would mean running additional sensors for all the channels you want to see.
The AIM MXL can display 6 values and show warning alarms for them. So, assuming you went for:
Oil Pressure
Water Temperature
Oil Temperature
Air Temperature
Boost Pressure
Battery Voltage
You would unfortunately need sensors for everything but the battery voltage - it does push the cost up!
Old Aug 18, 2013 | 01:40 PM
JonnyBravo's Avatar
JonnyBravo
This is one I've recently fitted to a Corsa, it uses a serial interface to stream ecu data from the Link ( ecu is off in the pic which is why the coolant temp is wrong )
You can calibrate just about any sensor to the dash but it does only have 4 auxiliary inputs so most of the data does come via the ecu.
By installing a data logger you can have tons of inputs
Billy_RS's Avatar
Billy_RS
Ah, my apologies!
Oil Pressure
Water Temperature
Oil Temperature
Air Temperature
Boost Pressure
Battery Voltage
Oh right I see
So that would be the same for a stack dash as well? I'd have to buy every sensor?
Old Aug 18, 2013 | 01:54 PM
Will Pedley Racing
Yes, I'm afraid so!
Old Aug 18, 2013 | 02:08 PM
Billy_RS's Avatar
Billy_RS
Yes, I'm afraid so!
Crap!
Thank you very much for your input, big help
Billy
Old Aug 18, 2013 | 04:38 PM
stevieturbo's Avatar
stevieturbo
C**t
Racepack IQ3 maybe another option.
http://www.racepak.com/Components/IQ3_Display.php
http://www.racepak.com/Components/UDX.php
Motec's new displays look pretty hot too. Although I'm sure you need a Motec to run them, at least for now anyway
A bit expensive for just a display though maybe. But they sure do look good.
http://www.motec.com/c125display/c125displayoverview/
Old Aug 18, 2013 | 04:49 PM
Billy_RS's Avatar
Billy_RS
Think I might just go for a stack 8130, comes with all the sensors for about a grand.
Looks the nuts too IMO
Fordmad!
Sep 29, 2015 07:03 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Si B
Sep 12, 2015 06:49 AM
imnoteasy
Sep 7, 2015 09:26 PM
