Alcohol Injection.
Old Mar 19, 2005 | 04:43 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default Alcohol Injection.
Like water injection, but far better.
People only use water I think as thats whats legal to use on Rallycars etc, and Alcohol inj is against the rules, and most road mods are derived from Racing/Rallying...
Anyone know anything about it?
Ive heard tons about it on US forums, people running mega power with no intercooler at all, just alky injection
I drive it daily and put about 250 miles a week on it. 31 pounds of boost (what's that, like 2.1 bar?) on pump gas and alcohol, all day and every day.
I use an injection kit that uses it's own nozzle and fuel source, similar to the Aquamist kit. www.alkycontrol.com.
It's very nice, I was getting some big knock at 20-21 psi on pump gas before, but with the alcohol injection 31 pounds daily is no problem.
I've had it higher, like 35 psi/2.4 bar, but it made me nervous pouring that much boost into my daily driver.
My car performs as well on 93 octane plus methanol injection as it did running straight 110 octane in the tank, it honestly is the best money I have spent on my car aside from the bigger turbo.
At 31 psi it's made 680 RWHP, but keep in mind that's through a heavy automatic transmission and a fairly loose torque converter, that would be closer to 750 through a standard trans.
That bests what I could do on plain pump gas by a little over 100 RWHP, hard to complain with that!
What do they mean by alcohol? Pure alcohol no? Methanol it seems from what he wrote? Where do you buy methanol or pure 100% alcohol from n what it cost?
Old Mar 19, 2005 | 04:48 PM
big_wig_074's Avatar
big_wig_074
its methanol mate,yeah! dunno,try b&q!!! or another diy shop!
Old Mar 19, 2005 | 04:50 PM
GARETH T's Avatar
GARETH T
wouldnt bother steve,, its a pain in the arse,,
plus the a/f ratio of methonal is like 6:1 ,, so i doute youll see any gains
richm's Avatar
richm
In those terms, "alcohol" will mean Methanol Steve, yes.
Don't loose sight of the corrosive effect that methanol has on a lot of rubbers and aluminium, so choose your system components accordingly
Old Mar 19, 2005 | 04:51 PM
GARETH T's Avatar
GARETH T
thats why i said its a pain in the arse
Old Mar 19, 2005 | 04:52 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Its not for power gaz, its to stop det enabling you to run fuckloads more boost on pump fuel rather than going onto race fuel, read the quote!
Just spraying a bit of pure methanol rather than water
Old Mar 19, 2005 | 04:53 PM
Chipperx2's Avatar
Chipperx2
It also makes you blind if u ingest it, and poisons you if you spill it on yer skin and don't wash it
but is highly flamable and cheap to make, doesn't produce as much CO2 etc etc
Old Mar 19, 2005 | 04:55 PM
big_wig_074
this what ur after steve?
http://www.worldwideracingfuels.com/catalog_c30755.html
Old Mar 19, 2005 | 05:00 PM
big_wig_074
gives original aircraft reasons for methanol in there!
http://www.dave-cushman.net/misc/mannject.html
Old Mar 19, 2005 | 05:01 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
It only seems to inject a tiny amount, so a 5gallon can would last for bloody ever.
Got the same worries about "relying" on water injection too tho, if it runs out or fails, blammo, but then you could say the same about a fuel injector, a sensor, anything really i guess
Old Mar 19, 2005 | 05:05 PM
big_wig_074
seems the germans originally used it mixed with water too,so even longer,apparently to stop it freezing at altitude,but think a 50 50 mix is good at any level,dunno why,explains in second link i think.dont like WI meself tho!
Old Mar 19, 2005 | 05:06 PM
GARETH T's Avatar
GARETH T
why run any of them,,, with good mapping,, and that massive interooler you wont have a problem
Old Mar 19, 2005 | 05:08 PM
big_wig_074
someone else asking this got some answers here
http://forums.club4ag.com/topic.asp?...TOPIC_ID=35929
Old Mar 19, 2005 | 05:13 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Im NOT interested in a water/meth mix or anything like that, im talking pure methanol spray here, like the link i posted.
Gareth- With my comp ratio and intercooler i dont think il have a problem at all on pump fuel, even at silly boost like 2.5bar, but can get good gains from ign advance too cant you...
Old Mar 19, 2005 | 05:14 PM
GARETH T's Avatar
GARETH T
some people just want it all
race fuel could be the way to go,, and have two maps
Old Mar 19, 2005 | 05:17 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
race fuel is horrendously expensive, and i want to be able to run my maximum on the road anytime i want, its a road car afterall, i dont want to go to the hastle of swapping fuels just to give it its all.
Old Mar 19, 2005 | 05:21 PM
GARETH T's Avatar
GARETH T
what happens if you can get hold of meth for a couple of weeks though?
Old Mar 19, 2005 | 05:28 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Il make sure i can, keep a stock, model shops sell it i think.
I dunno how much itd use.
Id prob not bother bearing in mind my car can probably take all the boost i want with no set anyhow.
This post was mainly to see if anyone knew anything about pure alky inj, and so far i guess not
Old Mar 19, 2005 | 05:31 PM
GARETH T's Avatar
GARETH T
sounds like you made your mind up already
Old Mar 19, 2005 | 05:32 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
not at all!
Old Mar 19, 2005 | 06:01 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
might wanna turn that 6 upisde down
Old Mar 19, 2005 | 06:02 PM
big_wig_074
ok mate!!!
have a look here,VERY well informed people it seems,talking everything from 50 50 mix to pure methanol with pump gas etc......!
http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=673
Old Mar 19, 2005 | 06:03 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
cool, good link
Rhys
Feb 15, 2006 02:58 PM
andre_k
Nov 27, 2005 03:40 PM
Andy-R
29
May 21, 2005 04:25 AM
