erst Inlet manifold connections - please confirm?
Old Mar 19, 2005 | 04:12 PM
L33 BYT's Avatar
L33 BYT
Default erst Inlet manifold connections - please confirm?
Have I reconnected one of the leads on manifold wrong?
Runs ok when cold but pops and bangs when warm and aux air plugged in.
Old Mar 19, 2005 | 04:23 PM
L33 BYT's Avatar
L33 BYT
Can any one confirm plug to sensor order.
Can cofirm Black to aux air (Unplugegd)
Blue to CSV
Old Mar 19, 2005 | 05:39 PM
DazC's Avatar
DazC
Brown socket to brown plug.
Blue socket to blue or grey plug
Yellow or white socket to yellow plug
Black socket to black plug!
Yellow = coolant temp sensor
Black = aux air valve
Brown = thermo time switch
blue = cold start injector.
Old Mar 19, 2005 | 05:55 PM
L33 BYT's Avatar
L33 BYT
Yellow is on the underneath of manfold right!
Old Mar 23, 2005 | 05:41 PM
L33 BYT's Avatar
L33 BYT
Car will not run right with this plugged in just kicks out black shit. Whats going on. AUx air (Black plug) from cold or hot
Old Mar 24, 2005 | 09:30 PM
DazC's Avatar
DazC
It won't do. It is the coolant temp sensor and as the ECU is detecting an open circuit, it will be throwing in fuel for -40 degrees conditions...
Change the sensor and see what happens..
Old Mar 25, 2005 | 10:04 PM
L33 BYT's Avatar
L33 BYT
They still available from some where like Halfords or Fords?
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Oct 5, 2015 09:57 PM
muz
Sep 30, 2015 08:29 AM
caprixpack
Sep 25, 2015 07:53 PM
